I use Command Arrow, not Option Arrow, but I probably set that in the Command window, and had DP retain the custom commands on its first startup. I assume you could do the same.philbrown wrote:Do Option + Right and left arrow still work to incrementally zoom in and out? I use that so much, it would probably be a dealbreaker for me if that no longer worked.
DP 10.1 out
Re: DP 10.1 out
Re: DP 10.1 out
Pinch zoom on the trackpad will speed things up for those of us who gave up using a potato (I mean mouse - I meant potato) for a MTP2.
- terrybritton
- Primary DAW OS: Windows
Re: DP 10.1 out
I've put Admiral Bumblebee's quick overview of DP 10.1 improvements over at the tutorials section, as it is very helpful.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Re: DP 10.1 out
Yep, I can’t imagine ever using a mouse again. The Magic Trackpad 2 is an incredible piece of hardware.MIDI Life Crisis wrote:Pinch zoom on the trackpad will speed things up for those of us who gave up using a potato (I mean mouse - I meant potato) for a MTP2.
Re: DP 10.1 out
Is anyone else seeing higher CPU usage on 10.1?
I just updated from 9.5x, and a tune I was working on is now choking, when it wasn't before. Nothing else has changed in the system or sequence.
Granted, this particular tune was close to maxing out at 2048 buffer size, but on 10.1, it just barfs unless I turn off the absurdly CPU spendy IK tape machines. It played fine before.
Anyone else seeing this?
Performer user since--HOLY CR*P--1986? YIKES!
Re: DP 10.1 out
Yes. Enabling MachFive3 maxed the CPU meter and made the cursor jerky.wheever wrote:Is anyone else seeing higher CPU usage on 10.1?
Re: DP 10.1 out
Well, that's a drag.
My comp is saying 18% total processor usage, but DP is saying it's maxed out. About half the cores aren't even being utilized. I'll never understand the DP processor meter, or why it doesn't use all available cores.
And thus it has always been.
Re: DP 10.1 out
10.1 takes longer to load my (fairly big) template. Also moving tracks and folders takes longer as well, including spinning balls. None of that happened before in 10.01 and 9.52
Mac Studio Ultra 128 RAM-Ventura
Hackintosh i9-128 RAM-NVMe and SSD drives-Monterey
PC i9-256 RAM-NVMe and SSD drives-Windows 10
828es-828-mk2-ADA8000
VEP7, some nice libraries and some nice hardware synths
Re: DP 10.1 out
Yes, it’s been like this as long as there has been a cpu meter. I don’t understand why it’s not fixed.wheever wrote:Well, that's a drag.
Re: DP 10.1 out
Anybody else having issues with retrospective MIDI ? MIDI recording works fine but when clicking on Region->retrospective MIDI all I get is mono-pressure, no note data
Thanks !!
Thanks !!
Mac Mini OSX 10.14.6 3.2 GHz Intel Core i7 64 GB RAM
DP 10.1
Pro Tools Ult 2019.6
Nuendo 10.2
Cubase Pro 10.5
Logic Pro X
DP 10.1
Nuendo 10.2
Cubase Pro 10.5
Logic Pro X
Re: DP 10.1 out
Holy cow! I just discovered 10.1, and I'm impressed. Lots of features for a .1 release.
I've been wanting (and requesting) MIDI clips for years. Nice to finally see them. And the ability to un-group them is cool.
GUI improvements. Zoom with trackpad. Velocity tool. MIDI editing improvements. Yay!
Thanks, MOTU!
Thanks, MOTU!
Bob
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Re: DP 10.1 out
“Pinch to zoom” on my Magic Trackpad (1st gen) isn’t working. It should, per page 331 of the User Guide.
Anyone getting this to work?
Bob
DP 11.23
DP 11.23
Re: DP 10.1 out
Hey there Phil. Are your templates created as DP templates, or just regular DP files you have built from scratch and are using as a template? ThanksPhil O wrote:terrybritton wrote:Phil O wrote:OK, so I got it to work in a newly created project by not using one of my existing templates, but the bug remains.
Re: DP 10.1 out
We need to do the metering trick we used 40+ years ago. Just put tape over the stinking DP CPU meter so we cant see it. Anyone got any digital masking tape?MIDI Life Crisis wrote:Yes, it’s been like this as long as there has been a cpu meter. I don’t understand why it’s not fixed.wheever wrote:Well, that's a drag.
Re: DP 10.1 out
Small bug I noticed.
When dragging the right end of a MIDI note to extend it, the MIDI note moves to C3 until you let go of the note. When you release it, it moves back to its original pitch.
This is for a single note drag/extension.
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
