TAKES & QUICK KEYS / WORK FLOW
so, i find myself needing to go through and select new take a lot. is there a way to select a set of tracks and add a new take to each without doing it to each one manually?
also, if you have any simillar quick key processes you're using to speed up work flow i'd love to hear them.
- musicarteca
Group the tracks, and when the group menu appears select new take, rename take and delete take from the parameters that you can choose to be grouped. Now lets say that you are recording a drum set with 8 tracks, every tame that you create a new take, choose rename or delete a take will affect all 8 tracks.
Pressing Control-Option-N is a short cut for creating a new take. Control-Option- up/ down arrow, is a shortcut to go to the next of previous take. Make sure that the tracks are record enabled to be able to use these shortcuts.
- rockitcity
Re: TAKES & QUICK KEYS / WORK FLOW
Check the Commands window. It's full of useful shortcuts. A bit overwhelming at first, but use the search function to find the areas you are looking for and learn the ones you need. It'll help a lot. Now, if I could just remember the shortcut to open the commands window...msmith92 wrote:...also, if you have any simillar quick key processes you're using to speed up work flow i'd love to hear them.
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
- yofo
That's funny , but there is nothing about takes in the commands window, I was looking for this just yesterday. I have a Transport and I was downstairs cutting guitar and the studio is upstairs so I wanted the Transport to change takes (in addition to record, play and locate) but it will only learn a "key command" and I couldn't find a key command in the commands window but I'll try what Musicarteca suggested, Control-Option-Nrockitcity wrote: Now, if I could just remember the shortcut to open the commands window...
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
ok. i found the group command but the new take thing only seems to work with MIDI? i'm using audio tracks only. when i group the audio what benefits do i get from it? you'd think you could select all the tracks and just do a new take and it'd change it across all the tracks or even if i decided to set a selection to a new bus it'd do it all at once. i know this is possible but it's not working for me.
