Suggestion on interface?
SuperDave
Post by SuperDave »
What would you suggest for an audio interface for my live rig, I only need four outputs (stereo FOH, stereo drummer headphone send). It doesn't need to have MIDI as my Axiom 61 already has that for me. Basically I'm trying to avoid using the laptop outputs, but want a higher quality audio signal. Bus powered a must. Thanks for your input.
PowerMac G4 Dual 867 Mhz/1.25 GB RAM/OS 10.3.8 | PowerBook G4 1.5 Ghz/2.0 GB RAM/OS 10.3.8 |DP4.12/MOTU 828mkII
BradLyons
Post by BradLyons »
Well, what do you need it for? If you just need basic outputs for live playing (not recording), the Presonus Firebox is a great solution for under $300. I set Anton Fig up with one for triggering Reason live on the Tonight Show (David Letterman) and it works great.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
SuperDave
Post by SuperDave »
Definitely looking for something for live use only, I have the 828mkII in the rack at home, and don't want to fool with pulling it out everytime I play. I'll check out the firebox, thanks.
BradLyons
Post by BradLyons »
Well if you have an 828mkII already, and I know this is way more money, but perhaps a second 828mkII would be ideal so that you don't have different drivers and a different interface to setup later. In other words, you have your system in the studio and your system live (this is the same reason I had a pair of Kurzweil K2500XS keyboards...one stayed in the studio, one stayed in a case for live use).
Thank you,
Brad Lyons
db AUDIO & VIDEO
Dwetmaster
Post by Dwetmaster »
I wish I could afford to double my rig like that. :wink:
Could be useful!!!
