Which is most recommended and stable at this point? I'm currently running 10.3.8 and DP 4.12. The usage would be to trigger backing tracks for a live band, and to send a click track to the drummer, maybe eventually getting into some lighting control. I also use my Korg Trinity to play B3 sounds, Pads, and Piano. I may try a softsynth in the future if there is one that will do all those without breaking the bank. So which DP/OS combo seems to best fit my situation with my current power under the hood? (1.5 Ghz, 2 GB RAM, 80 GB HDD)
Thanks,
David
Which DP Version/OS Version combination for Live Use?
PowerMac G4 Dual 867 Mhz/1.25 GB RAM/OS 10.3.8 | PowerBook G4 1.5 Ghz/2.0 GB RAM/OS 10.3.8 |DP4.12/MOTU 828mkII
- eriknorlander
Hi SuperDave,
I have been using DP 4.61 and OS 10.4.x for several tours without incident. I put "x" at the end of the OS number because I've used several of them from 10.4.3 up to 10.4.7. I haven't tried 10.4.8 yet.
Prior to this, I was ultra paranoid about using DP live with any version that was too new. Up until mid-2005, I kept my G4 667 Powerbook running only OS 9.2.2 (no OSX installed at all!) and DP ... are you ready ... 3.61. Total dinosaur setup. But it was rock solid.
After having a lot of success with DP 4.5 in the studio, I took the plunge and put it on a new Powerbook in the fall of 2005, then upgraded to 4.61 when that became available. Now one year later, I can report only success with the system. I should upgrade the HD in my Powerbook to a 7200 RPM drive, but even with the stock drive it still works fine with a few audio and MIDI tracks and minimal plug-ins.
Best regards,
Erik
Best regards,
Erik
G5 Quad 2.5GHz, 6 GB RAM, OS 10.5.8, DP 7.02, UAD-2 Quad, all IK Multimedia and Sonic Reality synths and plug-ins, DrumTracker, ApTrigga, NI Komplete 5 and 6, ImpOSCar, TimewARP 2600, Waves Gold, Nomad Integral, 2X 828mk3, UltraLite mk3, 3X micro express. 1967 modular Moog synthesizer, Minimoog model Ds, Voyager, other Moog things, Alesis A6, lots of other hardware synths. Hammond organ and Leslie, Kawai grand piano. Mics and guitars. Braun 3071 coffee maker.
http://www.eriknorlander.com" onclick="window.open(this.href);return false;
