BradLyons wrote:The HD192 is MOTU's interface, the 192I/O is the Digidesign interface.
Ah-- let's hear it for context! Please forgive my density!!
HD 192, 192 I/O-- got it, finally.
I guess my thinking was so UN-MOTU at the time of the post-- I've never even once considered buying, using, or even looking at a MOTU HD192. In fact, I'm pretty sure that I'm on my last MOTU interface at present.
BradLyons wrote:Well the Rosetta with a Sympony card is very cool to say the least, but it's a different mindset than ProTools HD. The idea of Symphony is to connect Apogee converters directly to your computer with a front-end DSP for real-time monitoring, no latency. This is the same concept as in ProToolsHD, however that's where it ends because you're now talking a NATIVE plugin system v/s a DSP plugin system. As you know, I'm a ProToolsHD user. I do use other setups too so that I'm up to speed on them all, but when it comes to my own work and the mixing I do for my church. I use ONLY ProTools. In my home studio, I run a ProTools HD3 Accel with a 192I/O with a second A/D card. At my church, I use a ProTools HD3 Accel with a 96I/O however my inputs are actually coming from a VENUE console via the Digilink cable. The inputs are from the stage which are technically the 192I/O. In Studio A, I use 32-channels of Apogee AD16X and DA16X.
The 192I/O is a VERY good converter, I love mine! You can't say that it's better or worse than the Apogee, only different. Sonically, the 192I/O is a top-shelf converter but the Apogee is more musical, a little more punchy. The 192I/O is more clean, so to speak. The difference with ProToolsHD isn't just processing on the front-end, but dedicated DSP throughout which allows for BEST optimization of the system. The plugins are written FOR THIS SYSTEM, giving them the most efficiency, the best sound quality, and the fact they just work! No third-party drivers to make everything talk, no buffers to route a third-party DSP card through, predictable performance, integrated hardware so everything just functions the way it was designed, etc.
In a native system, it's easy to say how many tracks and how many plugins you can get. But understand this, manufacturers do these specs to "wow" you. But who cares how many plugins you can run, it comes down to how many AND how good of plugins you can run. About 3 years ago, I setup a Digi002 and a ProToolsHD system side by side...BOTH using Apogee converters on the output so it was the same converters. I left everything at unity gain so not to alter the mix bus and cause internal, native dither (since ProToolsHD has analog sounding dither on level reduction, this wouldn't be fair for my test). Basically I was just testing the audio quality and plugin audio quality. I had the same session, the same plugins (using all Waves plugins), the same levels, etc. There was a definite difference in plugin quality between native and the TDM based plugins. I've done this same test with other native systems, and ProTools always came out on top BECAUSE of the TDM based processing.
WITH THIS SAID......YOU DO NOT HAVE TO HAVE PROTOOLSHD IN ORDER TO HAVE A POWERFUL, GREAT SOUNDING DAW THESE DAYS AND I WANT TO BE PERFECTLY CLEAR ON THAT. Programs like DP and Logic are wonderful, and have so much to offer! Adding things like Duende, LiquidMix, or a PowercoreFW add plugin quality that typically is only available in an HD system. There are also limitations with those products, but they do work and are excellent! Personally, I use ProToolsHD because of the sound quality, dependability, speed of which it works, the vast array of high quality plugins that are available for it, and the automation system which is the best automation on the planet as far as I'm concerned. Before I went ProTools HD, I was thinking of adding a second MOTU 2408mk3 and buying a Sony DMXR100 with a MADI option, an RME MADI converter, and Nuendo. But in the end, I'm glad I went ProToolsHD and the Control24.
But for those running Logic or DP and have no need or no desire to switch, but want to have high-level converters without any kind of latency....then the Apogee Symphony with your choice of Apogee converters is certainly worth a look.
Question.....
Why do you post such a rant about the merits of ProTools, on a MOTU forum..?? Save that ••••, while you're blowing each other over at the Digi site....
And, uh...leave the "church" •••• out.....Normally, it's referred to as a "gig"....
No need for the "hidden" codes........
Please go back and look through this thread, your answer as to WHY I posted about ProTools will be answered. Hers's a hint..... someone asked a question, I have the knowledge about it, and I answered it. To make this easy for you, see below:
Anyone have any details about an Apogee Rosetta with Symphony vs. PT-HD Core with 192?
The fan issue with HD is interesting...
The Accel Card has an awful lot of stuff on it-- is this better or just bulky?
$8k for HD1 Core plus $4k for the 192.
Rosetta $2700 plus Symphony $900
Second of all, playing out on the weekend is what is normally referred to as a "GIG". What I do is over-see a live production on a weekly basis to make sure the audio on-stage is getting down into the studio and that everything is locked to picture so that audio can be mixed for a live television feed, later posting that to BETA and ultimately mixing in surround on a weekly basis. That sir, is NOT a gig...that is a JOB, a responsibility, something that takes several hours of my morning, and one that has a great deal of resonpsibility, and one I'm proud to do.
Third, I treat everyone here with respect and expec the same in return. This is a user forum, a place to talk about gear, technology, and life in general in the music world. We all have different levels of experience and equipment we use, some more than others and some not as much. I have a GREAT deal of experience with over 15 years in this business, I have a vast array of product knowledge in installed and touring live sound, sound-design, post-production, and yes studio recording. In order to best understand the advantages and disadvantages of a product, you must also know the same about many other products. So if someone here doesn't answer the questions about ProTools HD v/s the Apogee Symphony setup or answers them with incorrect information, then there might be one less DP user out there instead. Likewise, someone might go out and buy the wrong products based on getting the wrong information here.
With my experience and the fact I enjoy posting on this forum, it is my responsibility to speak up about product questions so that the facts are stated, and stated correctly.
Sincerely and with respect....
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Frodo wrote:
But could you clarify your statement regarding Apogee being "quite a bit more money"? Other than Rosetta and Symphony, what did I miss?
You missed that the original post was not about the protools 192i/o, but rather the MOTU HD192. Go back and read it again with that in mind and all will become clear
I am VERY interesed in this comparison myself! I am definatey getting ready to buy a big ben within a week or 2, and while I'd love the get apogee converters , there are a bit out of my budget right now
I have the HD192 on my list as well ,but I am wondering how much differents there is in real world terms between the rosetta800 and the hd192 given they would both be clocked from a big ben?
I know well that greatness is the culmination of all the little things, but is it a subtle difference? or a very striking difference?
On a more superficial note.. I hate that the apogee stuff has no usable levels meters. Just signal present and over as best I can tell. Granted I have no gold records on my wall, but I find these things useful
Also with the apogee stuff I still have to find a suitable audio interface.
I understand that there are fixes for the fan noise issue. maybe motu is shipping with quiter fans??
Thanks for what ever info!!
edit.. Opps I guess thats already been answered
Yes, the thread was started back in March. I bumped it only a few days ago with a slightly different question that did not intend to involve the MOTU unit. In that sense, my question was slightly OT, but in that context I only wanted clarity with the references for the interfaces being discussed.
Somehow, I almost regret having brought it up again. This hasn't been a good week for communications around here.
