traveler spdif
tricky
traveler spdif
Post by tricky »
hi there i have just recently managed to record using spdif on my traveler, but ive noticed that my mic and line inputs no longer work, does this mean that when i use spdif it disables the mic and line inputs automaticly or is it a problem somewhere i would have thought that you could use all inputs at the same time. any help would be great thanks
gameu
Post by gameu »
Hi!
Using spdif should not disable any analog input. Something's going wrong somewhere... what's your setup, just in case?
tricky
Post by tricky »
hi there there thanks for your reply, not quite sure how i done it but it all seems to be working now, i only wanted to use spdif because all my line inputs are being used. ive just been informed that MOTU are releasing a new gadget called PRE 8 i think, basicly its a rack unit offering another 8 inputs which can be connected via the light pipe or firewire . and its going to be released in october for under £500.00. sounds just the ticket for me, i just hope its not £499.99. thanks again
