Mach 5 and Auto tune Crashing DP 5.1
I've seen both of these issues posted on the board before. Just wondering if anyone came across a solution for both or one or the other. Tried a search, but came up with nothing.
thanks in advance.
G5 2ghz
DP 5.1
Apogee Rosetta
Plugz etc...
thanks in advance.
G5 2ghz
DP 5.1
Apogee Rosetta
Plugz etc...
yep!! There are a few posts buried in threads hither and yon.
MachFive:
This seems to be a fairly common problem that MOTU have publicly acknowledged and are working on a bug fix.
To fix it;
- Quit all applications
- Go to /Library/Audio/Plug-Ins/Components and trash "MachFive AU.component"
- Go to Your User Folder/Library/Audio/Plug-Ins/Components and trash "MachFive AU.component"
- Go to /Library/Audio/Plug-Ins/MAS and trash "MachFive MAS.bundle"
- Empty Trash
- Shut down completely and reboot.
- Reinstall M5 v1.2.3
Antares AutoTune:
From Loudmac.com
http://www.loudmac.com/blog/motu/univer ... -plug-ins/
Antares Autotune Compatibility Problems With Digital Performer Universal Binary
There have been many reports of immediate crashes with Antares Autotune and DP 5.1. Click here to visit Antare••™s website for updates and the latest information.
In a nutshell, the latest AutoTune just doesn't work properly yet with DP 5.1, although all signs indicate that it should. You may want to contact Antares directly since their site is a bit vague.
MachFive:
To fix it;
- Empty Trash
Antares AutoTune:
From Loudmac.com
Chris, that's good news. Antares can drag its feet on such things, but it's nice to know that someone has gotten it to work.chrispick wrote:I got Autotune to work by installing and using only its latest AU version. I haven't run it through anything intensive, but it seems to work.
- tommymandel
On my older Powerbook, I'm using DP 5.1 (because I'm still running OSX 10.3.9 on it, and Tiger is a requirement for DP 5.1.1) and Auto-Tune AU latest version works without crashing. I think Antares was discouraging use of the MAS version, so I guess we're on the same page as far as that goes.HCMarkus wrote:ATune AU seems to be working fine for me too. ATune MAS was instant crashville under DP 5.1.
AUTO TUNE CRAsHING
Just to throw in a few cents as well -
Just upgraded to 5.1 and had the same issue with AT.
Sent the crash log off to MOTU and they responded right away - advising to make sure to delete the AT MAS from your hard drive - make sure the AT AU version is a go and then the AU version should load and run fine - Its been working for me in the studio with no problems.
Now I just read on Waves site that due to the major architecture changes with 5.1 that the Waves plugs are "Currently not supported" under 5.1 yet.
I think there needs to be some better planning next go round. - Basically 5.1 is forcing a Tiger upgrade and a slew of other issues for losts of folks.
I am still having issues getting the PLugSound / Ultimate Sound Bank to run - even after installing the v1.94 from USB's site - Iy simply crashes when and I add the instrument and any projects that have it assigned already crash upon loading....
Orca
Orca
Re: AUTO TUNE CRAsHING
Gotta do the same thing. Delete all related MAS bundles, use only latest AU components.orcasound wrote:I am still having issues getting the PLugSound / Ultimate Sound Bank to run - even after installing the v1.94 from USB's site - Iy simply crashes when and I add the instrument and any projects that have it assigned already crash upon loading....
Hey Tommy! You told me to go AU with ATune a while back, and you were sure right. The problem became really bad with DP 5.1, but resolved nicely with the AU version.
Orcasound: Use Waves AU. They work great! Pre-rendering works. It's sort of a pain loading old projects though. A reverb tail problem is also present, but appears to have been an ongoing problem with Waves, which I avoid by using Altiverb. A workaround is also discussed in these threads.
http://www.unicornation.com/phpBB2/view ... hp?t=14781
http://www.unicornation.com/phpBB2/view ... hp?t=14238
http://www.unicornation.com/phpBB2/view ... hp?t=14668
Thanks for all the input everyone here at the Nation.
