Playback at "half speed"
Martin Ward
Post by Martin Ward »
I have an audio track and I would like to convert it as though I had recorded it on a tape recorder and then played it back at half speed -- so the result should be an octave lower and last twice as long as the original.
As an algortihm, this should be a very simple operation, much the same as doubling the sample rate.
Can anyone tell me how to do this in DP, or if it can in fact be done?
(Using DSP to stretch to twice the length without transposing, and then to transpose down an octave without changing the length is not satisfactory -- the changes are too violent to result in a satisfactory sound.)
Martin
Frodo
Re: Playback at "half speed"
Post by Frodo »
Martin Ward wrote: (Using DSP to stretch to twice the length without transposing, and then to transpose down an octave without changing the length is not satisfactory -- the changes are too violent to result in a satisfactory sound.)
This is typical of the limits of how far one can go with such a process. The algorithms in Logic and Live, for example, might be a little better at such things, but you may want to consider a high-end app dedicated to the task. Pitch and time shifting to that degree is pretty radical with unpredictable results.
Beyond mere pitch and time shifting, it may be necesary to use a restoration app to clean up the result
stephentayler
Post by stephentayler »
Unfortunately this simple process is not yet do-able in DP, like it is in ProTools (pitch shift without time correction)
It can be done in MachFive by importing the audio and tuning down an octave.
Stephen
Martin Ward
Thanks for the replies Frodo and Stephen.
Unfortunately I don't have ProTools or MachFive. Maybe I'll just outsource it to my trusty old tape recorder -- a bit ignominious! First I'll see if I can get the same sound by another method.
Martin
Frodo
Post by Frodo »
Martin Ward wrote:Thanks for the replies Frodo and Stephen.
Doesn't Ableton Live have a free demo? Not sure if it's save-protected or time protected.
There may be some free demos or freeware utilities floating around.
What a shame. Digidesign's new X-Form in PT is just what you need.
bongo_x
Post by bongo_x »
tracktion does this really easily, just grab the edge and stretch it with pitch correction off. there's a demo on the mackie site.
it's crazy that DP, or any other DAW doesn't do this very simple operation.
bb
dosuna11
Post by dosuna11 »
If you have a G4 Pro Tools Free does this.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
soundsun
Post by soundsun »
dosuna11 wrote:If you have a G4 Pro Tools Free does this.
..that can boot into OS 9 :)
Macbook 2 gig with 2 gigs of RAM, 10.4.7, iMac G5, 1.9 Gig with 1.5 gigs of RAM ,10.4.6 DP 4.61
bjornln
Post by bjornln »
Pardon me, but isn't the simple answer.. Nano sampler ? Or have I missed something ?
Best,
B
stephentayler
Nanosampler!!!! What a genius.... yes it works just fine!!!
Martin, if you haven't upgraded to DP5, this would make it worthwhile!!
Thanks B!!
Stephen
Martin Ward
bjornln wrote:Pardon me, but isn't the simple answer.. Nano sampler ? Or have I missed something ?
Best,
B
I do believe you're right. I was sure it must be there somewhere. I'll try it out and see.
Thanks Bjornin (and again to everyone else).
Martin
stephentayler
BTW I just dropped a 5 minute stereo file into Nano, just to test. It took a while to load into RAM, but it worked perfectly.
Stephen
Frodo
Post by Frodo »
stephentayler wrote:BTW I just dropped a 5 minute stereo file into Nano, just to test. It took a while to load into RAM, but it worked perfectly.
Stephen
Now, that's good to know!
Tritonemusic
Post by Tritonemusic »
Nanosampler works great for this. I wish I would have seen this post earlier. Frankly, I'm almost shocked that you guys haven't tested this! Well, I'm sure people have tried it but, like me, never got around to posting anything about it.
What's really cool is automating nanosampler's pitch. Not something you'd want to do every day but it's nice to know that it works very well.
