I am trying to split a stereo recorded keyboard into two mono tracks for more control and easier mixing. What I have tried to do is duplicate the track that I want spilt, panned those in opposite directions, and bussed them to two seperate mono tracks. When I recorded those tracks onto the mono tracks they carried both sides of the stereo track without seperating right and left.
How do I achieve seperating these tracks?
splitting recorded stereo recorded keyboards
- scott dansby
If they were recorded stereo to dual mono...wich thats what it sounds like, you wont be able to seperate them as true stereo tracks.
I'd re-record if you can or maybe when you split the track add some delay on it much like people do when they double a guitar track. That will add some stereo imaging to it.
60% Of the time...it works EVERYTIME!!
http://www.zara-music.com
http://www.soundclick.com/zara
http://www.soundclick.com/mattradlauer
i would solo and pan the stereo track to the left, BTD mono track add to sequence, then do the same panned to the right. make sure there is nothing on the master buss that you don't want to go down with that synth.
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
- toofar
I guess I'm a little fuzzy on what you're after, but to turn a stereo track into separate mono's just strip the L and R from the filenames, rename them if you'd like, and you've got two mono tracks.
Bill
Bill
DP 11.32 | iMac 3.2GHz 6-core i7 & Monterey | Audient iD44 | FaderPort2 | MIDI Express XT | G4 dual 1 ghz MDD & Tiger | 2408 mk3 (x2) | A-500 PRO | Rosetta 200 | Toft ATC-2 | Mackie VLZ3 | JBLs | DP 4.6 | Live | 'n stuff
I'm not sure what you mean by "more control" over the tracks, but I assume you mean you'd like to have control over the stereo image itself - either widen it, narrow it, or put it off to one side, so to speak, while still maintaining the stereo image. Is that correct?
I think you can use "Trim" to adjust or constrain the stereo image.
Waves Gold, Platinum, and Diamond bundles feature a suite of Stereo Imaging plug-ins which will widen, narrow, or shift the stereo image.
