MIDI and DP 4.6
ronnie fitz
MIDI and DP 4.6
Post by ronnie fitz »
:confused: Hi there everyone
im having a prob.with DP 4.6 that i hope somone can help
me with.
for MIDI im using a roland sc88 if i create a MIDI track
and try to call up a bass patch everytime i move the
curcer it jumps back to all the piano patches
thats all it will let me pull up!!!
could somone else try this and let me know if it works for youthanks in advance
Ronnie
ronnie fitz
Re: MIDI and DP 4.6
Please somone try this
and let me know
im using a fastlane usb
and a roland sc 88
i just use it for piano and base sounds
but when i try to change patches in the patches list
it keeps jumping back to the first set of patches
Ronnie
sndhse
Re: MIDI and DP 4.6
Post by sndhse »
Ronnie it sounds like you have a default patch enabled.
Read this:
Choosing a default patch (sound)
The default patch is the sound that the track always begins with. It is remembered when you save the Digital Performer project so that the next time you open the project and press play, the default patch is called up from the synthesizer before playback begins so that the track will play with the correct sound. To select a default patch for a track, choose it from the default patch column.
Hope this helps
John
www.soundhousestudio.com
G5 Quad 6.5GB ram/2408MKIII/MTPAV/Mackie d8b
DP 6.01/OS 10.4.11
B4, Kontakt 2, Absynth 3, Stylus RMX, Ivory 1.5, Addictive Drums, Sampletank 2, Ivory, East west Gold/XP, East West Symphonic Choirs, Reason 2.5, Waves Platinum, Altiverb, Vst Wrapper etc...
ronnie fitz
Re: MIDI and DP 4.6
sndshe
i looked for that and i t is not there
the song im working on has no autiomation on it what so ever'
what im trying to say is in the main window when i try to call another patch it keeps going back to the piano secition
there i can pick any piano i wont it just will not let me go to the sub folders that have bass sounds or strings
stuff like that. i even staterd a new prog. and it atcks the same way
there also i dont know what to do?
try it with a sound mod. with MIDI and see if it works for you
with 2.5 it worked just fine
danny
Re: MIDI and DP 4.6
Post by danny »
If you can get by without MIDI "Event Chasing", try turning that off.
Dual G5 1.8, 10.4.8, 3GB RAM, SSL X-Logic 24 channel ADDA feeding RME card., MIDI Xpress, Liquid Mix, analog summing (Studer 902).
sndhse
Re: MIDI and DP 4.6
Post by sndhse »
All my mods are working fine, including patche selections. Here's another idea. Go to your "audio MIDI setup" highlite and delete the SC-88 from the list, then create a new one. Might reset the patch listings.
Hope this works out for you. I'll think of some other ideas if this one doesn't work.
John
DP 6.01/OS 10.4.11
ronnie fitz
Re: MIDI and DP 4.6
Thanks ill try that and see if that works!!!
ronnie fitz
Re: MIDI and DP 4.6
it dident work!
ill just have to wate to see what happons
it will do the same thing on any MIDI track i work on
thanks anyway
burger
Re: MIDI and DP 4.6
Post by burger »
Hey Danny,
Where do you go to find MIDI "event chasing" option. I've been looking for that.
thanks,
b.
Dual 2.5 gig G5 2.5 gig RAM. DP 4.52
2408 MK3, Digi 96 & 192. Pro Tools Accel HD 2. Various plug ins.
Tritonemusic
Re: MIDI and DP 4.6
Post by Tritonemusic »
burger
Re: MIDI and DP 4.6
Post by burger »
thanks 666,
sometimes looking in the manual can be a good thing!!!!
b.
