Constant Crashing on Intel MacMini
Jaime Lunn
Post by Jaime Lunn »
I updated to the UB 5.1 on my Mac Mini Core Duo 1GB RAM.
I have very few UB AU's. So far I have been unable to keep DP5.1 open for very long. It is constantly crashing, even if I just leave it doing nothing.
This is pants because it was running better under Rosetta. I have trashed prefs moved AU's in and out of the folder and nothing is making a difference. It is very annoying and I must admit a bit tedious.
Anyway must carry on trying to establish a definitive link (if there is one)
papageno
Re: Constant Crashing on Intel MacMini
Post by papageno »
Jaime Lunn wrote:must carry on trying to establish a definitive link
Look in
˜/Library/Logs/CrashReporter/
if there is DP crash log in that folder (should be).
Maybe you will get your hint from there.
+372 56222285
Jaime Lunn
Yes good thought.. I have been examining process viewer and found that Microsoft AU Daemon was running, which is the blasted Microsoft Office Auto Update feature. I have disabled that and removed from the start up items at login, since then DP...bastard.... I was just about to say it has stayed open but as I typed this it crashed again.. now lets look at the report
Jaime Lunn
would be good if I understood any of it but I know a few people who do so will check with them
i386 thread??
mcgwd
Post by mcgwd »
i dont own a mini but one thought maybe lack of ram, you have 1 gig but some of it is shared with the video card.
just some food for thought, launch activity monitor before DP see how much free ram is left.
hope this helps.
papageno
Post by papageno »
mcgwd wrote:maybe lack of ram
Lack of RAM shouldnt cause such symptoms.
Also: when DP was running under Rosetta, it needed and also used more ram than native version. Then it didnt crash either.
Post your DP crash log somewhere...
+372 56222285
widnikprod
DP% won't open some songs from 4.6
Post by widnikprod »
just installed DP5 on G4 dual 1.25 GHz powerPC 2Gb RAM. One song from DP 4.6 won't stay open past reading file window. program crashes. Song will open in 4.6. I have DP 4.6 and DP5 showing up in two places on drive applications and harddrive, Is this just routing or are their actually duplicates of both on drive? Could this be causing problem because DP doesn't know which one to use? I'd appreciate any help given.
Aramis
Re: DP% won't open some songs from 4.6
Post by Aramis »
widnikprod wrote:just installed DP5 on G4 dual 1.25 GHz powerPC 2Gb RAM. One song from DP 4.6 won't stay open past reading file window. program crashes. Song will open in 4.6. I have DP 4.6 and DP5 showing up in two places on drive applications and harddrive, Is this just routing or are their actually duplicates of both on drive? Could this be causing problem because DP doesn't know which one to use? I'd appreciate any help given.
Hell all !
I got DP 4.5 , 4.6 and 5 folders in my application folder ......and so I got different DP like 4.5 , 4.51 , 4.61 , 5.01 and 5.1 and I got no problem at all .....
Could you create a new file in DP 5 and use it to verify if it is your old 4.6 file that DP 5 do not like or else .....?
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
Aramis
Post by Aramis »
Jaime Lunn wrote:I updated to the UB 5.1 on my Mac Mini Core Duo 1GB RAM.
Hello !!!!
Have you tried to re-install from your original cd first and update to 5.1 after ?
Aramis ....
Jaime Lunn
Yes I trashed everything and re-installed, I disconnected an external hard drive I re-installed the MOTU firewire software for my 828MK2 and I am still experiencing problems. I loved the power of DP5 under Rosetta, I was slavering at the thought of UB. I will continue to run down the possibilities.
But hey I am still the proud owner of 2 G4 systems that get the job done!
Timeline
Post by Timeline »
Try taking the entire plugin folder out and see if it runs.
Also try running off internal audio engine.
Add them back one at a time if it runs
emulatorloo
Post by emulatorloo »
MOTU tech notes says that if you are on intel, you can only run
Universal Binary Plug-ins
Intel Only Plug-ins
So if you have a PPC plug-in there somewhere, you need to get it out of there.
go to motu site, tech notes page and search for DP 5 and plug-ins if my summary did not make sense.
kelldammit
Post by kelldammit »
from what i can tell, dp will ignore any non-intel plugs, so you can't use them anyway.
i haven't had any issues with crashing, but an interesting thing i have experienced is periodic...stuttering, as if the cpu is overloaded (meter shows not even 20%...i'm only talking 3-4 vi's here). it comes and goes on its own...even if i bounce down the audio...strangeness. i'll figure it out sooner or later. just curious if anyone else had similar trouble.
papageno
Post by papageno »
kelldammit wrote:from what i can tell, dp will ignore any non-intel plugs, so you can't use them anyway.
This is absolutely correct. PPC-only plug-ins cannot and will not load and therefore can also cause no crashes. You can trash them to regain some disk space.
+372 56222285
Jaime Lunn
I left a project out overnight with only native plug ins installed (I know PPC are not making a difference) I had one bus operating sending to a SPDIF o/p with a return aux open and some basic audio I had started editing.
To my surprise the project was still open so I have been trying a few things.
I opened a Modulo plug-in started playing that. Then pressed stop on the transport and went to access the hardware settings. DP crashed.
So the log is below if anyone fancies a crack at deciphering and any thoughts on what Wrapped MAS Module might mean? Looking at a couple of other posts I feel that this is going to be a straight forward crap release as various users are reporting problems with accessing basic functions.
Date/Time: 2006-08-13 10:00:26.932 +0100
OS Version: 10.4.7 (Build 8J2135)
Report Version: 4
Command: Digital Performer
Path: /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/Digital Performer
Parent: WindowServer [54]
Version: 5.1 (5.1)
PID: 314
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000032
Thread 0 Crashed:
0 DPPart2.dylib 0x0188054a WrappedMasModule::GetNumConnectedInputs() + 28
1 com.motu.DigitalPerformer 0x0010e989 0x1000 + 1104265
2 PerfEngine.dylib 0x0235e24c AudioRegistrar::UpdateDriverTrackOutput(ntrackRec**) + 132
3 PerfEngine.dylib 0x0235e4de AudioRegistrar::UpdateTrack(ntrackRec**, TrackAssignment const&) + 138
4 PerfEngine.dylib 0x022f4db2 TrackAssign::~TrackAssign [in-charge deleting]() + 194
5 PerfEngine.dylib 0x023507b3 AudioOutputBundleAssign::NotifyTargetChanged() + 67
6 PerfEngine.dylib 0x022f5a8b Target::UpdateDescription(bool) + 105
7 PerfEngine.dylib 0x0243a274 virtual thunk [v:0,-12] to EffectSettingsInfoRec::~EffectSettingsInfoRec [in-charge]() + 42476
8 PerfEngine.dylib 0x02348dc2 AudioBundle::AssignTo(std::vector<TargetDescription, std::allocator<TargetDescription> >&) + 330
9 PerfEngine.dylib 0x0234c38a AudioBundlePool::ReadBundles(FileChunkInfo const*, unsigned short, bool) + 316
10 PerfEngine.dylib 0x0234c7c3 AudioBundlePool::ReadAudioBundles(FileChunkInfo const*, unsigned short, bool) + 893
11 PerfEngine.dylib 0x0234c9f0 AudioBundlePool::RestoreBundleState(AudioDriverClassID const&, long) + 260
12 PerfEngine.dylib 0x02362582 DigiPerfAudioDriverClient::SetPreferredSampleFormat(SampleFormat) + 2620
13 com.motu.DigitalPerformer 0x00133c56 0x1000 + 1256534
14 com.motu.DigitalPerformer 0x0026f414 0x1000 + 2548756
15 AllUtilities.dylib 0x00d7e925 Provider::BroadcastChange(ProviderMessenger const&, Dependent*) + 71
16 GenericPanes.dylib 0x00f79f7d GlogButtonPane::Track(short) + 275
17 GenericPanes.dylib 0x00f7a009 GlogButtonPane::HandleClick(EventRecordAdapter*) + 35
18 PerfFoundation.dylib 0x027ce631 GlogPane::TryClick(EventRecordAdapter*) + 93
19 PerfFoundation.dylib 0x027c44d9 CompoundPane::DrawFrame(Rect*) + 89
20 PerfFoundation.dylib 0x027c49a2 CompoundPane::_Iterate(char, long (*)(GlogPane*, void*, short), void*) + 116
21 PerfFoundation.dylib 0x027c4ef4 CompoundPane::ClickSubPane(EventRecordAdapter*, GlogPane**) + 134
22 PerfFoundation.dylib 0x027c4f23 CompoundPane::HandleClick(EventRecordAdapter*) + 31
23 PerfFoundation.dylib 0x027ce631 GlogPane::TryClick(EventRecordAdapter*) + 93
24 PerfFoundation.dylib 0x027c44d9 CompoundPane::DrawFrame(Rect*) + 89
25 PerfFoundation.dylib 0x027c49a2 CompoundPane::_Iterate(char, long (*)(GlogPane*, void*, short), void*) + 116
26 PerfFoundation.dylib 0x027c4ef4 CompoundPane::ClickSubPane(EventRecordAdapter*, GlogPane**) + 134
27 PerfFoundation.dylib 0x027c4f23 CompoundPane::HandleClick(EventRecordAdapter*) + 31
28 PerfFoundation.dylib 0x027ce631 GlogPane::TryClick(EventRecordAdapter*) + 93
29 PerfFoundation.dylib 0x027cecc3 GlogPane::GlogMessage(short, long) + 263
30 PerfFoundation.dylib 0x027c2902 GlogWindowPane::DispatchClick(EventRecordAdapter*, short*, long*) + 110
31 PerfFoundation.dylib 0x027c8ec4 HandleGlogEvent(glogRec*, EventRecordAdapter*, short*, long*) + 916
32 com.motu.DigitalPerformer 0x00269e9c 0x1000 + 2526876
33 PerfFoundation.dylib 0x027d1793 DoGlog(EventRecordAdapter*, glogRec*) + 191
34 com.motu.DigitalPerformer 0x005af3be 0x1000 + 5956542
35 com.motu.DigitalPerformer 0x005afbdd 0x1000 + 5958621
36 com.motu.DigitalPerformer 0x005b04d7 0x1000 + 5960919
37 com.motu.DigitalPerformer 0x00002532 0x1000 + 5426
38 com.motu.DigitalPerformer 0x0000244d 0x1000 + 5197
Thread 1:
0 libSystem.B.dylib 0x9000a5c7 mach_msg_trap + 7
1 PerfMSL.dylib 0x00dc71db catch_exception_raise_state + 527
2 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90037ee7 mach_wait_until + 7
1 libSystem.B.dylib 0x9003a652 usleep + 82
2 PerfMSL.dylib 0x00dc90e0 PerfAssert::SetEnableDebugMsgs(bool) + 4418
3 PerfMSL.dylib 0x00dc8e09 PerfAssert::SetEnableDebugMsgs(bool) + 3691
4 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 3:
1 PerfFoundation.dylib 0x027e2003 PerfWorkerThread::GetThread() + 831
2 PerfFoundation.dylib 0x027e2101 PerfWorkerThread::GetThread() + 1085
3 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 4:
0 libSystem.B.dylib 0x90110b1f semaphore_timedwait_trap + 7
1 PerfEngine.dylib 0x0236697e PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 658
2 PerfEngine.dylib 0x023669a9 PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 701
Thread 5:
1 com.apple.audio.MIDI.CoreMIDI 0x96130adf XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
2 com.apple.audio.MIDI.CoreMIDI 0x9612903b MIDIInPortThread::Run() + 113
3 com.apple.audio.MIDI.CoreMIDI 0x96129d1b XThread::RunHelper(void*) + 17
4 com.apple.audio.MIDI.CoreMIDI 0x96131617 CAPThread::Entry(CAPThread*) + 93
5 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 6:
1 com.apple.CoreFoundation 0x9082369a CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x90822eb5 CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x914588da HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x914586f5 CAPThread::Entry(CAPThread*) + 93
Thread 7:
1 com.motu.MAS.framework 0x01ea06c5 0x1e4c000 + 345797
2 com.motu.MAS.framework 0x01ea07f6 0x1e4c000 + 346102
Thread 8:
0 libSystem.B.dylib 0x9002521f semaphore_wait_trap + 7
1 com.motu.MAS.framework 0x01e579ea 0x1e4c000 + 47594
2 com.motu.MAS.framework 0x01e9ff53 0x1e4c000 + 343891
Thread 9:
0 libSystem.B.dylib 0x9001aafc select + 12
1 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 10:
1 ...ple.CoreServices.CarbonCore 0x90cd7041 Delay + 118
2 ...opellerheads.rewire.library 0x1d1f27e8 RWPUnregisterDeviceImp + 21574
3 ...opellerheads.rewire.library 0x1d20da5c RWPUnregisterDeviceImp + 132794
Thread 11:
Thread 12:
0 libSystem.B.dylib 0x9002763c kevent + 12
1 ...ple.CoreServices.CarbonCore 0x90ca9ae4 PrivateMPEntryPoint + 51
Thread 13:
0 libSystem.B.dylib 0x900251a7 semaphore_wait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90ca9c8a MPWaitOnQueue + 198
2 com.apple.DesktopServices 0x9264ef3f TNodeSyncTask::SyncTaskProc(void*) + 143
3 ...ple.CoreServices.CarbonCore 0x90ca9ae4 PrivateMPEntryPoint + 51
Thread 14:
Thread 15:
Thread 16:
0 libSystem.B.dylib 0x900492e7 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90cd2b14 TSWaitOnSemaphoreCommon + 163
2 ...ple.CoreServices.CarbonCore 0x90cd29a0 AsyncFileThread(void*) + 72
Thread 17:
1 com.motu.mas.plugin.modulo 0x1ac31663 GetNthPluginClass + 995667
Thread 18:
1 com.apple.ColorSync 0x91596b8f pthreadSemaphoreWait(t_pthreadSemaphore*) + 35
2 com.apple.ColorSync 0x915b1088 CMMConvTask(void*) + 60
Thread 19:
2 ...ple.CoreServices.CarbonCore 0x90cd9ab1 TimerThread + 87
Thread 20:
1 com.motu.MAS.framework 0x01ec2570 MAS83079 + 15798
2 com.motu.MAS.framework 0x01ec25f1 MAS83079 + 15927
Thread 21:
Thread 22:
1 com.apple.audio.CoreAudio 0x91465a10 CAGuard::WaitFor(unsigned long long) + 212
2 com.apple.audio.CoreAudio 0x91465932 CAGuard::WaitUntil(unsigned long long) + 66
3 com.apple.audio.CoreAudio 0x914643a2 HP_IOThread::WorkLoop() + 690
4 com.apple.audio.CoreAudio 0x914640e9 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
5 com.apple.audio.CoreAudio 0x914586f5 CAPThread::Entry(CAPThread*) + 93
6 libSystem.B.dylib 0x90024b07 _pthread_body + 84
Thread 0 crashed with i386 Thread State:
eax: 0xbfffe6be ebx: 0x0235e462 ecx:0x1f310224 edx: 0xbfffe9c0
edi: 0xbfffe6be esi: 0x00000032 ebp:0xbfffe768 esp: 0xbfffe6a0
ss: 0x0000002f efl: 0x00010286 eip:0x0188054a cs: 0x00000027
ds: 0x0000002f es: 0x0000002f fs:0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x9c5fff com.motu.DigitalPerformer 5.1 /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/Digital Performer
0xd7a000 - 0xd90fff AllUtilities.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/AllUtilities.dylib
0xda3000 - 0xdaafff FileSystem.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/FileSystem.dylib
0xdb5000 - 0xdb6fff com.motu.MPO.framework MotuPublicObjects 3.1 (3.1) /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0xdba000 - 0xdbefff PerfError.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/PerfError.dylib
0xdc5000 - 0xdcbfff PerfMSL.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/PerfMSL.dylib
0xdd2000 - 0xdd4fff ResourceAccess.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/ResourceAccess.dylib
0xdda000 - 0xdebfff XML.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/XML.dylib
0xf05000 - 0xf43fff DPBasicUI.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/DPBasicUI.dylib
0xf6d000 - 0xfa4fff GenericPanes.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/GenericPanes.dylib
0x1808000 - 0x1a40fff DPPart2.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/DPPart2.dylib
0x1c1b000 - 0x1cc5fff HiLevelWrappers.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/HiLevelWrappers.dylib
0x1d2c000 - 0x1e0dfff com.motu.MidiSystem MidiSystem version 1.0 (1.0) /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0x1e4c000 - 0x1f0bfff com.motu.MAS.framework 4.0.0 /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0x1f30000 - 0x2016fff com.motu.DAE MotuDAE•„• 1.0 (1.0) /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/Frameworks/MotuDAE.framework/Versions/A/MotuDAE
0x2066000 - 0x211dfff OMF_AAF.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/OMF_AAF.dylib
0x2139000 - 0x258dfff PerfEngine.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/PerfEngine.dylib
0x2796000 - 0x2873fff PerfFoundation.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/PerfFoundation.dylib
0x28fc000 - 0x29bafff PureDSP.dylib /Applications/MOTU DP5 Folder/Digital Performer 5.1.app/Contents/MacOS/PureDSP.dylib
0x2ffb000 - 0x2ffcfff com.apple.textencoding.unicode 2.1 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x16e69000 - 0x16e7dfff com.MOTU.plugin.AudioExport.CoreAudio 1.5 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
0x16f24000 - 0x16fa5fff net.sourceforge.webcam-osx.common 0.8.6 /Library/QuickTime/macam.component/Contents/MacOS/macam
0x179b7000 - 0x17a9afff com.apple.audio.codecs.Components 1.4.6 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x17d78000 - 0x17d90fff com.MOTU.plugin.AudioExport.QT 1.0.1 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
0x180fd000 - 0x18126fff com.apple.audio.SoundManager.Components 3.9.2 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x181f4000 - 0x181f9fff com.apple.audio.AppleHDAHALPlugIn 1.1.7 (1.1.7a2) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x181fd000 - 0x18214fff com.motu.driver.FWA.HALPlugin ??? (1.2) /System/Library/Extensions/MOTUFireWireAudio.kext/Contents/PlugIns/HALPlugin.bundle/Contents/MacOS/HALPlugin
0x1846b000 - 0x185c0fff com.MOTU.MAS.plugin.ArcPan 2.4 /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
0x18634000 - 0x187bafff com.MOTU.MAS.plugin.Auralizer 2.4 /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0x188bc000 - 0x189a2fff com.MOTU.MAS.plugin.AutoPan 4.3 /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x189ef000 - 0x18ab7fff com.MOTU.MAS.plugin.BassManager 2.3 /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
0x18af9000 - 0x18d6cfff com.motu.mas.plugin.BassLine 1.1 /Library/Audio/Plug-Ins/MAS/BassLine.bundle/Contents/MacOS/BassLine
0x18e56000 - 0x18ee4fff com.MOTU.MAS.plugin.Buffy 2.4 /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0x18f14000 - 0x19010fff com.MOTU.MAS.plugin.Calibration 2.3 /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
0x1905e000 - 0x19122fff com.MOTU.MAS.plugin.Chorus 3.3 /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0x19163000 - 0x191e2fff com.MOTU.MAS.plugin.DCNotch 4.3 /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0x19209000 - 0x1937cfff com.MOTU.MAS.plugin.Delay 3.3 /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0x193e9000 - 0x194bafff com.MOTU.MAS.plugin.Dynamics 3.3 /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0x194fb000 - 0x195c1fff com.MOTU.MAS.plugin.Echo 3.3 /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0x1967f000 - 0x1980bfff com.MOTU.MAS.plugin.eVerb 4.4 /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0x19866000 - 0x1993ffff com.MOTU.MAS.plugin.Flanger 4.3 /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0x19987000 - 0x1999bfff com.MOTU.MAS.plugin.InvertPhase 1.1 (1.0) /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x199bf000 - 0x19a18fff com.MOTU.MAS.AudioUnitSupport 1.6 (1.0) /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
0x19e86000 - 0x19f71fff com.MOTU.MAS.plugin.MWCompressor 3.4 /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
0x19fbd000 - 0x1a0b2fff com.MOTU.MAS.plugin.MWGate 2.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
0x1a189000 - 0x1a334fff com.MOTU.MAS.plugin.MWEQ 1.3 /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
0x1a39b000 - 0x1a4defff com.MOTU.MAS.plugin.MWLimiter 4.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
0x1a545000 - 0x1a9f2fff com.MOTU.MAS.plugin.Model12 1.1 /Library/Audio/Plug-Ins/MAS/Model12.bundle/Contents/MacOS/Model12
0x1aac4000 - 0x1af6cfff com.motu.mas.plugin.modulo 1.1 /Library/Audio/Plug-Ins/MAS/Modulo.bundle/Contents/MacOS/Modulo
0x1b06a000 - 0x1b0fcfff com.MOTU.MAS.plugin.MSDecoder 2.3 /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0x1b12c000 - 0x1b232fff com.MOTU.MAS.plugin.MultiModeFilter 2.3 /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0x1b288000 - 0x1b3cbfff com.MOTU.MAS.plugin.MultiPan 2.4 /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
0x1b43f000 - 0x1b8abfff com.motu.mas.plugin.nanosampler 1.1 /Library/Audio/Plug-Ins/MAS/nanosampler.bundle/Contents/MacOS/nanosampler
0x1b982000 - 0x1baf8fff com.MOTU.MAS.plugin.ParaEQ 4.3 /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0x1bb5b000 - 0x1bc83fff com.MOTU.MAS.plugin.PatternGate 1.2 /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
0x1bcdb000 - 0x1bdacfff com.MOTU.MAS.plugin.Phaser 4.3 /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0x1bdf4000 - 0x1beddfff com.MOTU.MAS.plugin.Plate 2.3 /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0x1bf2c000 - 0x1c1c5fff com.motu.mas.plugin.PolySynth 1.1 /Library/Audio/Plug-Ins/MAS/PolySynth.bundle/Contents/MacOS/PolySynth
0x1c242000 - 0x1c33cfff com.MOTU.MAS.plugin.Preamp 3.3 /Library/Audio/Plug-Ins/MAS/Preamp-1.bundle/Contents/MacOS/Preamp-1
0x1c38d000 - 0x1c72afff com.motu.mas.plugin.proton 1.1 /Library/Audio/Plug-Ins/MAS/Proton.bundle/Contents/MacOS/Proton
0x1c7d8000 - 0x1c7eafff com.MOTU.MAS.plugin.Reverse 1.1 (1.0) /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0x1c84e000 - 0x1c8eafff com.MOTU.MAS.plugin.QuanJr 2.3 /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0x1c91d000 - 0x1c9b4fff com.MOTU.MAS.plugin.Reverb 3.3 /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0x1c9e4000 - 0x1caaffff com.MOTU.MAS.plugin.RingMod 2.3 /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0x1caf1000 - 0x1cc20fff com.MOTU.MAS.plugin.SonicModulator 3.3 /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0x1cc85000 - 0x1cd4cfff com.MOTU.MAS.plugin.Tremolo 4.3 /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0x1cd91000 - 0x1ce62fff com.MOTU.MAS.plugin.Trigger 2.3 /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
0x1cea7000 - 0x1cf89fff com.MOTU.MAS.plugin.Trim 4.3 /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0x1cfdd000 - 0x1d12ffff com.MOTU.MAS.plugin.TriPan 2.4 /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
0x1d1e7000 - 0x1d246fff se.propellerheads.rewire.library 1.7 /Users/jaimelunn/Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
0x1d286000 - 0x1d2e5fff se.propellerheads.rewire.library 1.7 /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
0x1da86000 - 0x1dab1fff com.MOTU.plugin.ControlSurface.HUI 1.2.1 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/HUI.bundle/Contents/MacOS/HUI
0x1dad2000 - 0x1db04fff com.MOTU.plugin.ControlSurface.MackieControl 1.2.1 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0x1db28000 - 0x1db61fff com.MOTU.plugin.ControlSurface.SAC_2_2 3.2 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
0x70000000 - 0x7010bfff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fd50000 - 0x8fd8bfff com.apple.QuickTimeFireWireDV.component 7.1.2 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x8fe00000 - 0x8fe4cfff dyld 45.3 /usr/lib/dyld
0x90000000 - 0x9016efff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901be000 - 0x901c0fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c2000 - 0x901fefff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90225000 - 0x902fafff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031a000 - 0x9076afff com.apple.CoreGraphics 1.258.33 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90801000 - 0x908c9fff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90907000 - 0x90907fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90909000 - 0x909fcfff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a4c000 - 0x90acbfff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90af4000 - 0x90b57fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bc6000 - 0x90bcdfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bd2000 - 0x90c42fff com.apple.framework.IOKit 1.4.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c57000 - 0x90c69fff libauto.dylib /usr/lib/libauto.dylib
0x90c6f000 - 0x90f14fff com.apple.CoreServices.CarbonCore 682.12 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f57000 - 0x90fbffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90ff7000 - 0x91035fff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91047000 - 0x91057fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91062000 - 0x910e0fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91115000 - 0x91133fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9113f000 - 0x9114dfff libz.1.dylib /usr/lib/libz.1.dylib
0x91150000 - 0x91306fff com.apple.security 4.4.1 (27569) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913f5000 - 0x913fdfff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91404000 - 0x9142afff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9143c000 - 0x91443fff libbsm.dylib /usr/lib/libbsm.dylib
0x91447000 - 0x914c0fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9150e000 - 0x9150efff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91510000 - 0x9153bfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9154e000 - 0x91622fff com.apple.ColorSync 4.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9165b000 - 0x916d8fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91705000 - 0x917affff com.apple.QD 3.10.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917d5000 - 0x91820fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9183f000 - 0x91855fff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91861000 - 0x9187bfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91885000 - 0x918c2fff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918d6000 - 0x918e1fff com.apple.speech.synthesis.framework 3.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918e8000 - 0x91920fff com.apple.ImageIO.framework 1.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91932000 - 0x919e4fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a2a000 - 0x91a40fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a45000 - 0x91a61fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a66000 - 0x91ac4fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91ad4000 - 0x91ad8fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ada000 - 0x91b35fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b39000 - 0x91b76fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91b7c000 - 0x91b96fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91b9b000 - 0x91b9dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91b9f000 - 0x91b9ffff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91ba1000 - 0x91c2bfff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c32000 - 0x91c32fff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c34000 - 0x91c79fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91c81000 - 0x91ca6fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91cad000 - 0x92230fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9226d000 - 0x9261ffff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9264c000 - 0x926d0fff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9270c000 - 0x9293efff com.apple.Foundation 6.4.6 (567.27) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92a4a000 - 0x92b28fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92b45000 - 0x92c32fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92c42000 - 0x92c59fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92c64000 - 0x92cbbfff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92ccf000 - 0x92ccffff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92cd1000 - 0x92ce1fff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92cef000 - 0x92cf7fff com.apple.speech.recognition.framework 3.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92cfd000 - 0x92d02fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92d08000 - 0x92d99fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92dad000 - 0x92db0fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92db3000 - 0x92dd0fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92de0000 - 0x92de6fff com.apple.print.framework.Print 5.1 (192.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92dec000 - 0x92e4ffff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92e73000 - 0x92eb4fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92edb000 - 0x92ee8fff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92eef000 - 0x92ef4fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92ef9000 - 0x931ebfff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x932f0000 - 0x932fbfff com.apple.opengl 1.4.10 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9336a000 - 0x9336afff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9336c000 - 0x93a25fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93da6000 - 0x93e20fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93e59000 - 0x93f1afff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93f5a000 - 0x93f5afff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93f5c000 - 0x9410afff com.apple.QuartzCore 1.4.8 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94158000 - 0x94199fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x941a1000 - 0x941dbfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94356000 - 0x94365fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9436c000 - 0x94377fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x943c3000 - 0x943ddfff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x943e3000 - 0x9469afff com.apple.QuickTime 7.1.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94a58000 - 0x94a75fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x95b0d000 - 0x95b0efff libCyrillicConverter.dylib /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x95b10000 - 0x95b11fff libGreekConverter.dylib /System/Library/CoreServices/Encodings/libGreekConverter.dylib
0x95b15000 - 0x95b2bfff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x95b2d000 - 0x95b4efff libKoreanConverter.dylib /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x95b50000 - 0x95b51fff libLatin2Converter.dylib /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
0x95b53000 - 0x95b54fff libLatin5Converter.dylib /System/Library/CoreServices/Encodings/libLatin5Converter.dylib
0x95b56000 - 0x95b59fff libLatinSuppConverter.dylib /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x95b5b000 - 0x95b69fff libSimplifiedChineseConverter.dylib /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x95b6b000 - 0x95b6cfff libSymbolConverter.dylib /System/Library/CoreServices/Encodings/libSymbolConverter.dylib
0x95b6e000 - 0x95b6ffff libThaiConverter.dylib /System/Library/CoreServices/Encodings/libThaiConverter.dylib
0x95b71000 - 0x95b83fff libTraditionalChineseConverter.dylib /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x96124000 - 0x9615afff com.apple.audio.MIDI.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x96524000 - 0x96524fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96b6c000 - 0x96b71fff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97e35000 - 0x989e7fff com.apple.QuickTimeComponents.component 7.1.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x996bc000 - 0x996d9fff com.apple.OpenTransport 3.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
Model: Macmini1,1, BootROM MM11.004B.B00, 2 processors, Intel Core Duo, 1.66 GHz, 1 GB
Graphics: Intel GMA 950, GMA 950, Built-In, spdisplays_integrated_vram
Memory Module: DIMM0/BANK 0, 512 MB, DDR2 SDRAM, 667 MHz
Memory Module: DIMM1/BANK 1, 512 MB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 0.1.24
Bluetooth: Version 1.7.5f10, 2 service, 0 devices, 1 incoming serial ports
Serial ATA Device: ST98823AS, 74.53 GB
Parallel ATA Device: MATSHITADVD-R UJ-846, 743.91 MB
USB Device: TOSHIBA USB 3.5"-HDD, TOSHIBA, Up to 480 Mb/sec, 500 mA
USB Device: USB Device, Up to 12 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Hub, Up to 12 Mb/sec, 100 mA
USB Device: BCF2000, BEHRINGER, Up to 12 Mb/sec, 500 mA
USB Device: ShuttleXpress, Contour Design, Up to 1.5 Mb/sec, 500 mA
USB Device: Lexicon MX200, Lexicon, Up to 12 Mb/sec, 500 mA
USB Device: Microsoft Wireless Intellimouse Explorer® 1.0A, Microsoft, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
FireWire Device: OXFORD IDE Device, Oxford Semiconductor Ltd., Up to 400 Mb/sec
FireWire Device: 0x101800, 0x1F2, Up to 400 Mb/sec
FireWire Device: LaCie mini HD, LaCie Group SA, Up to 400 Mb/sec
