anybody tried the new powercore drivers yet?
Tinoo
Post by Tinoo »
Going to V2 killed a few of my plugins (like MasterX3) :(, and I couldn't go backwards because Poco flashing was needed to update and downgrading was impossible, but the new drivers finally solved the problem. :)
Teen Oooh wrote:Going to V2 killed a few of my plugins (like MasterX3) , and I couldn't go backwards because Poco flashing was needed to update and downgrading was impossible
MX3 was one of the many plugs Unicorners had trouble with.
Teen Oooh wrote:...but the new drivers finally solved the problem.
Phew! Good news; thanks.
Feelin' a little braver...
Mr_Clifford wrote:OK I did it......Anyone else game?........ Go on MonkeyMan, you know you want to.
I can't see any point, quite frankly.
OK, OK; you talked me into it! :D
The Ape Man wrote:Just headed over to http://www.tcelectronic.com/Default.asp?Id=1259.
They've taken the TCAU link I was concerned about on page 1 down:
http://www.tcelectronic.com/media/TCAU135.dmg
Hopefully now they can get it right?
The link used to simply access TC AU 1.3.05, even 'though it read "TC AU 1.3.7". Duh.
Any wonder they're under the microscope here?
Hang on; let me see if I can do it... Unga, Bunga... Unga, Bunga...
How was that? lol:
Haven't been able to find the latest TC AU installer.
It's still not up there.
If it's not included in the installer, we should probably wait. :roll:
I won't risk running the demos, 'though.
Haven't seen the installer yet... may have to remove plugs manually...
Later tonight... report back tomorrow... slipping into guinea pig mode... deep breaths... :lol:
Mr_Clifford
Post by Mr_Clifford »
monkey man wrote:Haven't been able to find the latest TC AU installer.
TCAU 1.3.7 is included with the installer for TC 2.0.1.23 (seriously, how many decimal points do you NEED in a software version number?) you can uncheck the 'demo/optional' plug-ins, which is what I did, considering I have PCI mkI and can't run them anyway. I suggest you remove the plugs manually before you run the installer. The last beta version I had to install the demo plugs just to get the normal ones to work, and this intstaller didn't get rid of them. So I've got redundant 'previous' versions of the demo plugs on my system still and have to wade through them in DP to get at the ones I can actually use.
Like you said, the plug-ins haven't changed one bit in behaviour or GUI since about version 1.6 so it's debateable whether it's worthwhile 'updating' if your system works.
Wow, thanks Cliffo! I've been watchin' the TC site for nothing.
Oh, just remembered we were watching the site for nothing anyway! :lol:
Mr_Clifford wrote:...(seriously, how many decimal points do you NEED in a software version number?)
One of life's great mysteries, I agree. :D
Mr_Clifford wrote:...you can uncheck the 'demo/optional' plug-ins, which is what I did, considering I have PCI mkI and can't run them anyway. I suggest you remove the plugs manually before you run the installer. The last beta version I had to install the demo plugs just to get the normal ones to work, and this intstaller didn't get rid of them.
Yeah, the manual delete thing. :roll:
It's always a worthwhile precaution for me.
I even do it for DP upgrades, especially seeing as I keep my MAS plugs in "category" folders and the installers have NEVER found them.
Mr_Clifford wrote:So I've got redundant 'previous' versions of the demo plugs on my system still and have to wade through them in DP to get at the ones I can actually use.
Hey, maybe the installer doesn't get rid of them 'cause it's looking for redundant plugs, but, as we've noted, they've been the same since time immemorial!
Mr_Clifford wrote:Like you said, the plug-ins haven't changed one bit in behaviour or GUI since about version 1.6 so it's debateable whether it's worthwhile 'updating' if your system works.
Well, the other day
you wrote:"Anyone else game?........ Go on MonkeyMan, you know you want to."
I didn't even realise I had that need 'till you told me! :lol:
Also, I've found monkeys just can't help themselves... push buttons! :lol:
Thanks for everything, Cliffo... off to install... Cheers. :wink:
Mr_Clifford
I installed 2.0.0.23 last night...
1) Audio recorded but "greyed out" upon stopping transport.
2) MasterX3 (again) plays up. This time it wont even open its window, let-alone pass audio!
3) I followed the procedure you suggested, but there is no option to install your PCIMkII bundle without copping all the demos! I installed the demos, removed them and ran DP.
I realised I should have re-run the TC AU scan app as soon as DP started loading; the AU scanner tested all of them somehow!
I quit DP, re-scanned the plugs and tried again. No go.
I ran the PoCo app and tried various settings. No go.
Hi Monkey Man - I pulled this over from the other thread.
Have you got the 'non-beta' 2.0.1.23 from the TC site? That's the one that's working for me. I'm also still stuck with all my useless DEMO plugs which come up in DP when I go to put a plugin on. I've deleted them from the VST plug-in folder so I suppose I could run the TCAU patcher again, but, well... it's working at the moment and I'm loathe to mess with it.
emulatorloo
Re: anybody tried the new powercore drivers yet?
Post by emulatorloo »
jgest wrote:I'm just wondering if it is worth taking the step into powercore driver 2.01.
Most would agree that 1.96 is far more stable than the recent 2.00.
thanks
2 was working for my on my dual g4.
I upgraded to 2.01 and the interface to several of the plugs just disappeared -- that is, a white rectangle where the UI used to be. They seemed to still function, but no way to adjust anything.
I removed everything and went back to 1.96 for the time being. (couldn't find the old 2 download.)
Mr_Clifford
emulatorloo wrote:I removed everything and went back to 1.96 for the time being. (couldn't find the old 2 download.)
It's not like they added anything significant to version 2 anyway!
emulatorloo wrote:I upgraded to 2.01 and the interface to several of the plugs just disappeared -- that is, a white rectangle where the UI used to be. They seemed to still function, but no way to adjust anything.
This happened to me too. Forgot to put that one in my list!
Thanks, looman. :wink:
Cliffo wrote:Hi Monkey Man - I pulled this over from the other thread.
Thank you for saving me the trouble, Cliffo. Sorry I had no luck finding the thread myself.
It's pathetic, I know. Good old Apple "Mail" coughed it up and it was the first click of the day...
Cliffo wrote:Have you got the 'non-beta' 2.0.1.23 from the TC site? That's the one that's working for me.
The previous (shakey, of course) version I was running was the v2.0.b21
beta.
At least the GUI problem wasn't there...
:shock: Just checked the extensions folder... 2.0.1 b23... :shock:
The date I'd recorded for this file was 2006-07-07.
If TC's put a new one up since, this may help, as you say Cliffo.
Anyway, the old 2k lightnin' connection's chugging away now, and should take care of it in, oh, about a week. :D
Cliffo wrote:I'm also still stuck with all my useless DEMO plugs which come up in DP when I go to put a plugin on. I've deleted them from the VST plug-in folder so I suppose I could run the TCAU patcher again, but, well... it's working at the moment and I'm loathe to mess with it.
Scan away, dude. The patcher's never caused a problem for me.
Any time I suspect DP or PoCo could do with a reminder of what's where, I scan. It's sort of worked like trashing DP's prefs for me...
I've tended to lump it in with Cycling '74's "Pluggo AU Scan" application, which I got in the habit of using 'cause every time you altered the contents of your Pluggo VST folder, DP wouldn't know until the app "told it"!?
I only tried the demo when it came out, but isn't this how Fxpansion's VST to AU Adapter worked? Any change meant re-scanning, methinks.
Of course, repairing permissions after installing pushes my buttons too, as it's a similar pattern. :D
Oh, yeah, I hope you don't mind my taking the liberty with the "Cliffo" thing.
We're Aussies. It's quicker to type.
If you don't like it, I'll change 'cause...
I'm an Aussie. I'll learn to type quicker. :lol:
Mr_Clifford
monkey man wrote:Oh, yeah, I hope you don't mind my taking the liberty with the "Cliffo" thing.
No worries mate. Throw another prawn (cause we don't actually call them 'shrimp') on the barbie. It's what they used to call me at high school.
BTW - I trashed the DP AU thingo today and when DP rescanned all the AU plugs, all the PoCo plugs came up with the message "Passed but may degrade performance" - what is that supposed to mean? I checked them and all the plugs work, but now I'm nervous again.
Mr_Clifford wrote:No worries mate. Throw another prawn (cause we don't actually call them 'shrimp') on the barbie.
Thanks, ya dag.
Don't we have prawns 'cause they're big, and shrimps are, well, Prawn-Heads?
Prawn-Head wrote:It's what they used to call me at high school.
What, Prawn-Head?
Hey, better I put words into your mouth than, er, prawns! :lol:
Prawn-Head wrote:BTW - I trashed the DP AU thingo today and when DP rescanned all the AU plugs, all the PoCo plugs came up with the message "Passed but may degrade performance" - what is that supposed to mean? I checked them and all the plugs work, but now I'm nervous again.
"Passed but may degrade prawnformance" in my experience translates to:
1) "When things get shakey, this plug gets flakey"
or
2) "Ditch this plug unless you're in love."
Funny, methinks, but true.
4 times out of 5, the offending plug's been worth removing. :wink:
