Is their a way to get logic to recognize the names you have given specific channels using CueMix ?
It would be sooo nice to be able to use the CueMiux names as as assignable input channels in Logic as trying to work out the routing of 2 x 828 (like which mic is on which channel is on which logic input (#1-32)) is just a nightmare !!
Simon
Routing Q for 828 /Ligic Pro users
Name them
Just name them "828_a_1-2" or somthing like that in your autoload song environment layer. I use my 828 to sub mix external samplers and name the input objects according to the instruments on them (eg 828 11-12 which I think without opening Logic is the first pair of ADAT Format is "String/Winds"). IT doesn't hurt to make a little excel spreadsheet as the adat inputs tsarting at 11-12 is a bit confusing. Good luck
