Bounce to Disk
grimepoch
Post by grimepoch »
My only mention of freeze was to see if it worked in relation to BTD since they are similar in the fact that audio is written out to disk.
I too use a second computer with KORE for the same reason, so I don't have to freeze anything. Works rather nice, although KORE is a bit of a pain at the moment, that is probably going to go and I will continue to use Rax.
When you are bouncing, do you see the synths running on the other machine or have you already recorded them down?
[MacPro-4x2.66/7G/OSX10.5.2 - 2x896HD - ADA8000 - Lucid Genx6 - DP5.13 - Logic 8.02 - 2xUAD1e - ExpressXT - Mach5 - MX4 - Korg LegD - impOSCar - Battery3 - uTonic - Rapture - DimPro - Vanguard - Reaktor5 - Absynth4 - FM8 - Pro53 - Vokator - Waldorf Ed - Addictive Drums - Melodyne - Ultra Analog - Zebra2 - WaveArts - - Altiverb - Etc. ]
[Virus TI - Virus B - Waldorf Q - Waldorf uwXT - Supernova II - Nord Rack 3 - JP8080 - XV5080 - Fantom X7 - Triton Rack - Pro/cussion]
jordanz
Post by jordanz »
Does MOTU respond to tech support emails anymore? Still haven't heard anything back from them.
ejv
Post by ejv »
well.......i finally was able to download the LAME MP3 codec into my dual 2.0 G5, 10.3.9 and was able to convert to an MP3 file. now the problem is i can't play the file. it is grayed out. am i using the wrong OS? any suggestions? thanks in advance, EJV :shock:
rentadrummer
Post by rentadrummer »
ejv wrote:well.......i finally was able to download the LAME MP3 codec into my dual 2.0 G5, and was able to convert to an MP3 file. now the problem is i can't find the MP3 file. any suggestions? thanks in advance, EJV :? :roll:
If you just don't know where the file was saved, start the bounce process again and look at the bottom of the window. It should indicate where the file is being saved. Then cancel the bounce and go look to see if your original file is there.
Ron
chrispick
Post by chrispick »
Well, unless you directed it otherwise, it should be in the "Audio Files" folder of your current DP Project. That's the default route.
Not there? Run a name search via Spotlight.
grimepoch
Post by grimepoch »
They are using 10.3.9....no spotlight :) Hehe, I use spotlight ALL THE TIME when I forget where I put a sample, file, movie, whatever.
I know it adds overhead, but damn, it helps me find stuff!!!
jordanz
Post by jordanz »
OK - I've tried AIFF, the builtin SDII, Movie, everything. Nothing but dead air. What am I doing wrong?
* I can hear the tracks fine when I play back
* I bring up the tracks window and then select All
* Then, I choose Bounce to Disk
* I select MP3 (or whatever) and click OK
HELP! I can't get any response from MOTU tech support. Is Kafka in the room?
grimepoch
Post by grimepoch »
Wow, yeah something is seriously wrong here. Never seen that happen.
Questions and suggestions:
Q: If you create a new project and add some stuff and try to bounce, same thing? Is it happening on everything?
Q: If you try freezing a track, just pick one, does it record blank audio as well?
Q: Did you try trashing your preferences and having DP build a new set?
Q: Did you try a reinstall?
Q: Did you try repairing permissions? Sometimes this helps.
That's all I got. Also, did you try calling MOTU instead of emailing them?
Mr_Clifford
Post by Mr_Clifford »
jordanz wrote:OK - I've tried AIFF, the builtin SDII, Movie, everything. Nothing but dead air. What am I doing wrong?
Could be a stupid question, but, have you checked that you've selected the correct output bus in the BTD dialogue?
I've had 'dead air' bounces a few times when I forgot to check the output bus and it was set to one of my other outputs for some reason.
jordanz
Post by jordanz »
Mr_Clifford wrote:Could be a stupid question, but, have you checked that you've selected the correct output bus in the BTD dialogue?
Checked and re-checked. Everything is set to Main 1-2.
Also, I trashed my prefs and checked the permissions on the DP folder. I even opened new and older projects. Still nothing.
-JZ
jordanz
Post by jordanz »
OK - some progress. Freezing the tracks worked. I'm able to bounce the frozen tracks to disk. What does this mean?
Mr_Clifford
jordanz wrote:OK - some progress. Freezing the tracks worked. I'm able to bounce the frozen tracks to disk. What does this mean?
Were you trying to Bounce-To-Disk VI tracks?
DP will only 'bounce' actual audio tracks and not the output of the 'unfrozen' VI's.
chrispick
Post by chrispick »
Dude, had you even mentioned VIs in your original post this problem would've been solved a long time ago. I'm glad you figured it, but next time try to be specific with your query info. It could save you a lot of time and anguish.
To clarify: Bounce-to-disk (BTD) via your master-out only sums audio tracks. VIs tracks must be converted to audio track either via freezing or merely routing and recording to an empty track (which is what freezing does in an automated way) before you can BTD.
jordanz
Post by jordanz »
chrispick wrote:To clarify: Bounce-to-disk (BTD) via your master-out only sums audio tracks. VIs tracks must be converted to audio track either via freezing or merely routing and recording to an empty track (which is what freezing does in an automated way) before you can BTD.
These are NOT virtual instrument tracks. These are real audio tracks (of me playing the drums).
grimepoch
Post by grimepoch »
Do you have more than one 'Main Out' defined in your AudioBundles? If so, maybe you are selecting the one in BTD that doesn't come from anywhere.
