Hey guys,
I just bought an UltraLite to use with my laptop which has one 4-pin Firewire port on it. I'm looking at getting a 6-pin PCMCIA cardbus Firewire adaptor, but I read that the PCMCIA slot doesn't deliver much power. I'd like to keep the system mobile, do any of you use a cardbus firewire adaptor to power your Ultralite? If it doesn't work, is there a different option you'd recommend (battery pack for the UltraLite, etc.)?
Thanks a bunch!
Micah
UltraLite Firewire power
- rockitcity
PCMCIA firewire cards typically don't deliver any power to attached devices. You need to get a power supply that plugs into the side of the card to power whatever you attach to it.
Some of the firewire PCMCIA cards ship with a USB power tap that gets power from adjacent USB ports. The one that came with my Adaptec card has two USB connectors, so I guess it sucks power from two ports, which is not much good on a Powerbook where you have one port on each side. I've never used it, so I can't comment on how long it may last on internal battery power. My guess is not long.
Mobility is great with the Ultralite and Traveler, but I think you'll need some reliable power source if you plan to record for more than an hour or so.
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
