DP5.01 unexpected quit while cutting & editing
WSVP
Post by WSVP »
anyone the same? sometimes when i cut or edit single or grouped tracks dp gives me the spinning ball and quits without warning or error-descripition. i installed dp5 beside dp 4.61. 4.61 was perfect. also 5 needs much more time copying parts of tracks somewhere else.
any suggestions.
thanx, robinsky
While I like a lot of the new features in DP5, after extensive testing I have found DP 5.01 to be fairly unstable. The auto-punch-in/out is completely unusable crashes every time. In general DP5 seems very prone to crash. This has been confirmed on multiple systems and I have seen other posts regarding both these issues. Looks like I will be sticking with 4.61 for a bit.
Kazrog
Post by Kazrog »
Frodo wrote:
Kazrog wrote:I'm still having the crashes. I've done everything I know how to do. Can't go back to 4.6.1, I'm using too many 5.x features. I'm just going to have to live with the crashes until MOTU fixes them.
Kaz-- are you using both a FW hard drive and a FW audio interface perchance?
No, I've got a secondary internal SATA drive, and a MOTU 828 Mk II (Firewire) interface. This is on a dual 2.5 G5 with 1.5 gigs of RAM, and tons of disk space.
All my drives are error-free, optimized with TechTool. I use a program regularly called AppleJack that repairs permissions and does a lot of other OS X cleansing processes. Under DP 4.6.1, I never had any crashes.
I've rid my sequence of any unused soundbites, I've flushed the undo history, etc. I'm working on a project where I have a group of 8 mono tracks that I edit simultaneously. I am going to be doing some single-mono track editing today for another instrument in the project, so I'll let you know if that's more stable. I regularly toggle "Edge Edit Copy" on and off as I need it, but I've had crashes regardless of its state.
I'm running at 1024 samples/buffer and I'm keeping my CPU meter at about 25% or less most of the time. I've frozen and disabled any VIs in the sequence. I don't know what else to do at this point, I've done just about everything a sensible DP user can.
Shane McFee
Recabinet | Kazrog LLC
papisax
Post by papisax »
I also still am haing problems with DP 5.01. Besides what I had done last week, which is mentioned below, I have reinstalled OSX and I am still getting freezes with DP 5.01. Does anyone have any suggestions.
This is the first time any of mac audio systems behaved like a Windows XP audio system. I am disappointed. My previous post is below. Take care.
Papisax
I am running a Dual 1.25 GHZ G4, 2 GB of Ram and a 120 GB hardrive. I did not have any problems with DP 4.61. Since I have been using DP 5.01 my computer relentlessly freezes. I have to constantly power it down.
I have ran Disk Warrior, defragmented the drive, Repaired Permissions, Reinstalled DP from scratch (making sure to remove all prefernces, etc), emptied all caches. I even ran tech tool pro to check out the hardware, and everything passed all the tests.
Does anyone have any suggestions? Is anyone also having problems. I have been using DP since 3.11. This is the first time DP is not working properly on my system. Your attention to my question is greatly appreciated.
papisax
Post by papisax »
I will tell all of you this:
I saved 4.6 versons of all of my songs (I am in the middle of finishing a Latin Jazz CD which I started in 4.61), removed DP 5.01, cleaned all DP and MOTU preferences etc. and reinstalled DP 4.61. And guess what? My computer is working perfectly!
May be it is a confilct with 3rd party plug-ins, etc.. But there is a problem. I am very frustrated because I have spent over 2 weeks trying to figure this out.
I hope this post is of some use.
Papisax
Kazrog
Post by Kazrog »
No problems doing single-track editing here. The crashes happen when you start editing groups of tracks. Obviously, most of us here rely on the ability to edit groups of tracks, so this is a serious (inexcusable) bug. Anyone report this to MOTU yet?
Shane McFee
Kazrog
Post by Kazrog »
Bumping this thread to the top... does anyone know if this bug has been reported to MOTU?
Shane McFee
thinkof1
Hallelujah!!!
Post by thinkof1 »
MOTU COMES THROUGH!!!
I though I was going to have to switch to Logic since DP started crashing almost everytime I edge edited or crossfaded or even hit undo.
Now in 5.1 this all seems to have been fixed! Now it's back to work.
Digital Performer 5.12
Macbook Pro 2.4 ghz 4GB RAM 160GB HD
Power Mac G5 Dual 2.0 ghz 2GB RAM 320GB HD
Motu 828 mkII
