Anyway, I kinda wish I did the Black lion stuff just before all the buzz ( and the price increase for the digi002r). Am glad this mod is available. More testimonies pls!
Did they warn you this was going to happen ? What are they saying with regards to this issue ?arbeeny wrote: The unit behaves fine, however there is one point that bears mentioning. After the clock mod, the unit will not properly sync to other clocks. It wants to always be the master.
You don't need to send the 2408 with the card. They have it.TrakMstrE wrote:....I have a 2408 mkI. I'm planning on getting a PCI-424 card soon. Will this mod work on any version of the 2408, and does the mod require sending both the breakout box ANd the card? Just want to be sure I didn't miss anything....Thanks!!
Edison
I was not informed up-front that the modified Traveler needs to be the clock master. It was only after I noticed it drifting in and out of sync as a slave to my RME equipment (Which has a pretty damn good clock).iMAS wrote:Did they warn you this was going to happen ? What are they saying with regards to this issue ?arbeeny wrote: The unit behaves fine, however there is one point that bears mentioning. After the clock mod, the unit will not properly sync to other clocks. It wants to always be the master.
The simplest solution would be to only use one at a time. For example you could record guitar through the Traveler as the clock master. Then switch to record vocals through your 002R and make it the master. Odds are you will run into problems if you need to run both masters at the same time. The other alternative is that you can try to run your clock synchronization signal over coax/BNC connections if your equipment supports this. I have not tried this so I cant promise that it will work.Sergievsky wrote: But therein lies the problem, if you have two gears who don't like to be slaved, what do you do?
Thanks for that bit of info.... Eazusa749a wrote:You don't need to send the 2408 with the card. They have it.TrakMstrE wrote:....I have a 2408 mkI. I'm planning on getting a PCI-424 card soon. Will this mod work on any version of the 2408, and does the mod require sending both the breakout box ANd the card? Just want to be sure I didn't miss anything....Thanks!!
Edison
I sent mine with only the 2408 mk3 for both mods.
They don't need to do anything with the card.
So here is the deal for me.
Wow. Someone went deep sea diving for this one.eixb wrote:TOSlink is a transport. TOSlink's format is typically S/PDIF...although way back when toshiba created it, it actually carried a proprietary raw data format.giles117 wrote:TosLink Is a format....
