I have my ReMOTE 25 MIDI Controler plugged into my G5s USB port. Before I upgraded to DP 5, this configuration worked flawlessly. I could control my soft sampler (Mach 5) just fine. Now, however, It appears as if I'm not getting any sort of MIDI signal to Mach V or any of the DP 5s SIs. I remember in DP 4, when a MIDI signal was being sent, an indicator would come on on whatever SIs GUI I was looking at. No such indication now. I haven't changed anything in DP 5s prefs that I am aware of. I just started using it. I did check to ensure all the MIDI controllers drivers were up to date. Everything in AMS appears normal as well.
I mostly do straight audio so, this isn't a huge deal at the moment. I do have one project however that has some supplimental strings I recorded via MIDI back in DP 4 that I would like to re do. I don't particularly want to use Mach Vs GUI to hunt and peck. I need my key board back. Any suggestions?
What happened?
- bug67
- Primary DAW OS: Windows
What happened?
Dual 2.7gig PowerPC G5 with 8gig RAM OS X 10.5.5
MOTU 828mkII
PreSonus DigiMax LT
Novation ReMOTE 25
Digital Performer 6, Logic Studio 8, NI's Guitar Rig2, BFD, Mach V, Mesa Boogie DC-5, Shure, AKG and Rode mics.
MOTU 828mkII
PreSonus DigiMax LT
Novation ReMOTE 25
- twistedtom
- bug67
Thanks for answering. Yeah, I got everything set up correctly to record and playback/monitor MIDI. It's acting like it's not receiving a signal at all from the controller. Weird 'cause the controller works fine with my other sequencer (GarageBand)twistedtom wrote:You have to assign a audio out put on the track the VI is on and then you can select it with a MIDI track and it should play. Perhaps this is what you need to do.
MOTU 828mkII
PreSonus DigiMax LT
Novation ReMOTE 25
MOTU 828mkII
PreSonus DigiMax LT
Novation ReMOTE 25
