i'm currently running T2 on an old powerbook g4 1ghz, but I'm about to get an intel Macbook 2ghz. does anybody here know if I can safely use the Ultralite with this new proposed setup (intel macbook + tracktion 2)?
thanks,
-andrew
will the Ultralite work with Tracktion 2?
The UltraLite should work with your MacBook -- get the latest drivers from the MOTU website, which are Intel-compatible.
But I don't think Tracktion is running natively on an Intel Mac yet (but I'm not a Tracktion user, so I don't keep up with their updates, so I could be wrong). You might be able to use T2 through Rosetta, but I haven't a clue as to how well it'd run, or if it'd run at all.
Though you should be able to use the UltraLite with T2 on any PPC Mac which meets the requirements for the MOTU drivers/T2.
