Performer and Atmosphere
Hello to all excused my English bad one!!! They are a new customer of Performer and I find it fantastic!!! I have only 2 problems. With Trilogy, it does not work to me on Performer while on LOgic!!! And Atmoshpere hardly the Performer cargo is closed to me!!! You never it is capitato? Thanks••¦!!! Dankan
- sndhse
Hi Dankan. Ok, so what your saying is... Your new to DP and you find it fantastic. You have 2 problems. 1) Trilogy will not work in DP, but does work in Logic. Forgive me but I don't understand the 2nd problem.
We need more information.
What computer are you using? eg) G4-G5-Macintel?
What OS are you using? eg) OS 10.3, OS 10.4?
I would suggest writing the problem in your own language. Someone might beable to answer you here within this forum.
Just a suggestion
John
Just a suggestion
John
- Spikey Horse
Atmosphere
Atmosphere needs quite a CPU and much memory. So I think the problem though unstated is Atmosphere doesn't work due to lack of processing power.
Trilogy and Atmosphere work on my dually G4 1.42
I'm trying to install atmospere on my Receptor and having a hell of a time.
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few
Ciao a tutti..!!! Mi scuso con il mio inglese, e allora provo a scrivere in Italiano!!! Io ho un G5 dual 1.8 con 4 gb di ram, e ho un problema nel caricare Atmoshere, mi fa chiudere il Performer..!!! Volevo solo sapere se vi è capitato, per capirne la causa..!!!
Grazie a tutti e scusate, studierò l'inglese..!!!
pozzo... ciao Dankan... la prima cosa quando incontro un problema con software sono trasferimento dal sistema centrale verso i satelliti gli ultimi aggiornamenti dallo sviluppatore. Vada al Web site di spectrasonics ed assicurisi voi avere gli ultimi aggiornamenti. Sto facendo funzionare DP4.5 (e DP5 provato) e non ho avuto problemi con c'è ne del roba di spectrasonics. Mi sono assicurato che ho avuto gli ultimi aggiornamenti. buona fortuna.
