:arrow:I'm waiting to finish the setup because of the data drive question. RPM, cache. Any other input on the data drive is helpful.
TIA
BH
Based on an article I read in Sound on Sound, July 2003 I chose a Hitachi/IBM Deskstar 120gb drive and put it on the internal ATA100 bus. They did a bunch of tests, in Logic, re track count. All drives were 7200 RPM, all with 8mb cache. The numbers were like this for a single drive using large files (that is, not little short snippets of audio) :bh wrote:As far as the HD is concerend. I agree that 250 GB is probably the way to go. I have a question though. Do you think I'd be better of with a 16 MB cache ultra ATA instead? Maybe I'd get an 8 MB cache ultra ATA for the backup and a 16 MB cache ultra ATA drive for the data drive? Or maybe even 2 - 8 MB cache ultra ATA drives and split the audio files between the 2 drives as is suggested in the DP getting started guide? But if I went that route, then I'd need a PCI card to run the 2nd drive.
I have had great luck with Western Digital and Seagate -- have had several Maxtor drives fail, but not recently. The IBM/Hitachi is great.bh wrote:Wow!!! great feedback.
May not be so outdated if, like the OP, you are using a Quicksilver Mac from 2001 or 2002! In that case, the priniciples and tests in that article still apply.DonaldDriver wrote:That sound on sound article was from 2003, its too outdated to even think about now.
Best place I have seen for HD information is www.storagereview.com
Like what? I know I have a ton of stuff in mine that I don't need but are there specific files etc..t hat I can get rid of also, i knew my way around OS 9 pretty well but I don't know OSX too well in terms of configuring things.bh wrote: I removed a lot of items that don't need to be there for recording.
