Motif Patch Name Issues
artmusicsouth
Post by artmusicsouth »
I have a motif ES6 and I have the .midnam file in my MOTU folder in the MIDI device folder. Unfortunately I am not getting the patch names, only the Patch 0 - 127. Does anyone have any htoughts on how I could corrcet this? I am on a Mac G5 by the way.
Thanks.
mhschmieder
Post by mhschmieder »
All that you need these days is to have your Motif ES 6 added as a device in Audio MIDI Setup. Digital Performer then finds the patch names automatically, when you select Motif->Channel1/etc. for the Output destination of a MIDI track.
Rather than waste time instructing how to add a device in Audio MIDI Setup, I'll wait first to see if you already know how to do that. I am assuming for the moment that you simply weren't aware that the whole ballgame has changed since Apple added Core MIDI support a year or so ago to OS X.
roxmooth
Post by roxmooth »
The same thing happened with my motif rack. What I did was went to the audio/MIDI preferences and removed the motif and created a motif again. It also didn't load my jv1080 expansion cards. Assuming you've loaded dp5 from 4.? Hope that works for you too.
mhschmieder
Oh, I thought the patch names were supplied/supported by Apple as part of Core MIDI, not by MOTU. I'll have to check my own MOTU/DP folders then before upgrading to DP5 this weekend, to make sure I don't lose my own Motif ES patch maps.
artmusicsouth
I deleted the motif from my Audio/MIDI set up in Apple and that did it. Thanks all for the help.
artmusicsouth
Well, maybe not. It seems that I am now getting general MIDI patch names without all the MOTIF names.
soundperspectives
Auto configure MIDI devices
Post by soundperspectives »
Setup > autoconfigure MIDI devices > start. That works for my Motif Makes a new Motif with all patch names. I end up for some reason with motif 6-1 and motif6-2 and motif 6-3 and motif 6-4. I am connecting through MIDI so I know that I only have 16 channels. My problem is that When I change a patch the other ones change to it but I'll figure this out.
Motif6 - Mbox2 -Kontakt2 -Dp 4.61 G5 powerbook G4
GMarcelK
Post by GMarcelK »
As far as the 1080 is concerned, go to the Motu DPx folder>extras>expansion board setup. Run that tool, setup your cards and there you go!
Marcel
iMac | fast! | OS 10.6.7 | Ultralite MK3 | DP 7.22 | too many plugins
