Config studio settings in DP5
Finelytuned
Post by Finelytuned »
Is it just me or is there NOT any written info regarding the config studio settings in DP5. I recently received my upgrade. How do you set the prime seconds, work quanta ( huh?), and max work percent so I achieve the optimal cpu performance?
I tried every combination possible and one day the mac flies like a jet and the next time ( with no new data AND with the exact same settings) I'm back to greatly disabling tracks! WHY IS THAT? :roll:
Can someone PLEEESE....help me get my head around configuring these settings so I can get consistent audio performance?
G-5 dual 2.3 Ghz, 512 L2 cache, 2.5 gig Ram
Michael K Johnson
RE/Max Properties S W II
Orlando 407-857-7600 x 305
gtrnstuff
Post by gtrnstuff »
+1
I can't find any info on this either. Just left the defaults alone.
sndhse
Post by sndhse »
You can find info on theses settings in the DP 5.0 addendum pdf that accompanies DP. It's on the installer disc.
John
gtrnstuff
Post by gtrnstuff »
Thanks, I thought I read that pdf but I must have been in a hurry.
Yep, there it is, just another paragraph without much fanfare.
Spikey Horse
Post by Spikey Horse »
hmmm... it does gve the impression that a lot of features in DP5 were last minute additions.
Or perhaps just that just that the manual was printed well in advance of the release.....
tommymandel
Post by tommymandel »
I thought I saw that information in the smaller Getting Started with DP5 book that came with the big manual...
sndhse
Post by sndhse »
Tommymandel. I thought that myself. Pg 23 "Getting Started" but this "Studio Configuration" section doen't have the new config settings. ie (work Quantra etc..)
John
twistedtom
Post by twistedtom »
Do you leave your computer on all the time? I find that running Macjanitor and fixxing permissions helps alot.
