19" wide screen
- daniel.sneed
19" wide screen
Any one tried once using a wide 19" screen ?
I am thinking to take the plunge. I think it fits better my way of staring long times to DP sequence editor.
Any known issue ?
Thankx for advices
dAn
Any known issue ?
Thankx for advices
dAn
dAn Shakin' all over!
- Spikey Horse
- daniel.sneed
strange afirmation
My old powerbook Titanium came with a wide screen.
That's the reason why I'd like to stick to this type of view.
If you can find any further information, it would be of much interest.
4:3 vs. 16:9
Just keep this in mind:
Screen with same diagonal (for example 19'') has more area when sides are equal. The biggest 19'' screen would be square. The more difference you get between longer and shorter side the less screen area you get.
This all comes down to basic geometry and math.
The bottom line:
19'' widescreen (16:9 ratio for example) is actually smaller than
19'' normal screen (4:3 ratio)
The bottom line:
+372 56222285
Re: 4:3 vs. 16:9
thats true, but wouldnt you be able to see more tracks in the mixing board with the larger horizontal dimensions even though the total area is less? the mixing board is typically a rectangle not a square, right?papageno wrote:Just keep this in mind:
The bottom line:
Re: 4:3 vs. 16:9
Of course it all comes down to what you need.lane_hagood wrote:wouldnt you be able to see more tracks in the mixing board with the larger horizontal dimensions even though the total area is less?
If your mostly need to see a mixing board which fits better on more narrow screen then widescreen is perfect for you.
I am working with scores and I need to see both, horizontal and vertical.
+372 56222285
- twistedtom
- mhschmieder
What is the current measuring criteria, and is it consistent? The reason I ask is that I was briefly in the computer monitor business in the early 80's, and I remember it being very precise and consistent as the diagonal of visible screen area.
Yet these days when I go into a store and see the specs, my own measurements don't even come close. Sometimes they match the full enclosure diagonal, which on an iMac G5 may be twice as big as the actual visible screen area. Sometimes it seems to match the width instead.
What gives? Are these numbers "real" anymore?
