I purchased and loaded MachFive and was going through the tutorial but my library is not visible where it's supposed to be. Also, it does not recognize my sustain pedal. I am using a Yamaha MOTIF ES7 as my controller. I am using DP4.61 on a Mac G4-dual 1.25GHz w/1.75 G of RAM.
Any thoughts?
Instruments not showing up/no sustain
Same problem, nothing visible ?!
Now we are two crying and screaming !!!
I have the same problem than you, no informations in all the left part of the screen (from top to the bottom). If I "clic" somewhere I can see the lists but nothing stay wroten so it 's hard to memorise everything I did !!!!
Sorry for the spelling mistakes but I'm French and not specialized in English language.
RE: Visible Instruments in the Interface
Hey DDClark777,
Did you purchase MachFive and installed straight fromn the disks with no updated installs from the website of motu...? Well, I did the same thing and had the same problem. You'll need to update the box version and trash a couple of files and install the update. I'm not sure which file to delete but they will tell you... After that, you'll be good to go... (I was)
