Metronome click audible on recorded track
nor
Post by nor »
I have had a problem with the metronome click sound being fairly audible on a recorded track. I know that I've had the metrnome bleed through far in the past because of recording with FX on a track. I don't think I had FX on when I recorded this.
Has anyone else had this problem? I'm not sure of what's causing it.
I'm using DP 4.6.1 on a Mac G5 with OS 10.4.2.
Thanks,
nor
yofo
Post by yofo »
It will come in through the mic from your headphones.
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
David Polich
Post by David Polich »
If it's playing through monitors, it can also be picked up by an acoustic or electric guitar pickup - I've had that happen.
Check also that you don't have the output for the click routed through some aux buss by mistake - again, I have also made this mistake in the past.
