BTD to .AIF/,WAV gone after Tiger and DP Upgrade
After upgrading to Tiger 10,42 and DP 4.6 I no longer have the options to BTD for AIF or WAV. I reinstalled LAME to enable the MP3 option so now all I can bounce are mp3's and QT.mov.
Before the upgrade I had all options with 10.39 and DP 4.5
Has anyone else had this problem?
G5 2.5 4G Ram
Motu 2408 Mk2
MTP AV
Tiger 10.42
DP 4.6
G5 2.5 4G Ram
Motu 2408 Mk2
MTP AV
Tiger 10.42
DP 4.6
- vbassguy
Re: BTD to .AIF/,WAV gone after Tiger and DP Upgrade
yep... me too... exact same problem...... i have no way to export anything except SDII and Quicktime movie..,
which is a bummer as my clients typically expect me to forward .wav and or .aif files....... i e-maild magic dave at motu and he told me to install LAME.frameworks which i have done to no avail...... currently i have to save my 4.6 project as a 4.12 project then quit 4.6 and open 4.12 then i can export .wav or .aif....... big freakin hassel... i am pretty sure it's something i'm missin....just hav'nt found it yet........ i have posted a couple of times re: this issue tho none of the GURU'S have responded....until then i'll use this workaround...
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
www.RRRPROD.com
Don't have that problem. Sounds weird.
- sdfalk
Fine over here.
A Metric Halo ULN8-3D…mmmmmmm
- vbassguy
sdfalk...... what do you think you are doing differently
than those of us who are experiencing this problem??
G4 dual 1.42 ghz 10.4.2 - DP 4.6- PT 6.9.2 002r
PCI 424 24 I/O..896HD Mach 5..... I know the equipment ,in my case is different ......is there some sort of BTD or Export preference setting we are missing???
thanks for any response......
www.RRRPROD.com
www.RRRPROD.com
Under '/library/audio/Plug-Ins/MOTU Audio Export' you should find 'Core Audio Export.bundle' along with the Lame and Quicktime bundles. Without that file there is no access to other export types - AIFF, WAV, etc. The only thing I can come up with re why it didn't install is that I used an updater file to install the program rather than reinstalling from the original CD and then running the update. If you have a copy on a backup, just drag it from there. Otherwise, reinstall should work.
- vbassguy
Chuck S......thanks....gonna give it a try......
www.RRRPROD.com
www.RRRPROD.com
- vbassguy
Chuck S......U R THE MAN!......... fresh install off the 4.5 disk and re-install 4.6 and all is well in the land of audio export.......thank you.....very cool.....
www.RRRPROD.com
www.RRRPROD.com
Thanks Chuck S,
You were correct.. The Core Audio Export bundle was not moved from the previous system into the new system after upgrading to Tiger. Once I manually moved it into the Library/Audio/Plugins/Motu Audio.. all is back to normal..
Many thanks to everyone that posted..
J
J
