are the 8 analog outputs -10 or +4 on a 2408mk2 ?
is possible to switch from one to another ?
thanks
I don't remember where I found this, but it answers your question:
The analog inputs on the 2408mkII ship at a default of +4db. You can easily switch the inputs on the 2408mkII to -10db, if desired. Disconnect the power cable from the 2408 mkII and remove it••™s cover. Be sure to get all of the screws. Three on the front, two in the back, and two on either side. When you remove the cover you will see 8 small plastic jumpers that are in line with the 1/4 connectors.When one pin is covered with the jumper the inputs are operating at +4db.When both pins are covered the inputs are operating at -10db.If you would like to set any of your analog inputs to -10db, simply cover both pins with the plastic jumper.
I pulled the cover off my 2408 to check what it was set for.. Very easy to do, just take your time and don't lose any screws.
