Traveler 1.07 update
As every other company, Motu should contain notes of what's been fixed in every firmware update...
I have just tried to install 1.07 - my Traveler is currently 1.05. The updater says the Traveler is not in upgrade state (it is, and the 1.05 updater sees it), and then crashes (the first time I tried it took Windows down with it).dagnilsen wrote:Has anyone tried this?
(I have 1.05 now)
I wondered about using the 1.05 updater with the 1.07 bin file, but I'm not confident that this would be safe.
Paul
Traveler Firmware 1.07 has been optimized to minimize overzealous relay clicks.
Very best,
Brian Choi
MOTU
1280 Massachusetts Avenue,
Cambridge, MA 02138 USA
http://www.motu.com
Very best,
Brian Choi
MOTU
http://www.motu.com
re: Traveler 1.07 update
I was having this problem, too. Finally installed successfully after first installing the 32-bit Firewire drivers and then working with a FAQ from MOTU support pages titled 'Windows does not recognize my Traveler when updating the ROM'.pwhodges wrote:I have just tried to install 1.07 - my Traveler is currently 1.05. The updater says the Traveler is not in upgrade state (it is, and the 1.05 updater sees it), and then crashes (the first time I tried it took Windows down with it).l
There was still some funky behavior in the 'verify' step when the install dialogs offered no 'quit' option (after the update was successfully installed).
The 32- bit driver appears to work fine - I'm running Sonar at 2.9 ms latency with the ASIO drivers.
Hope this helps.
Dan Ash
White Plains, NY
