help!!!!
help!!!!
i dont know what happend but im pulling up mach 5 in DP now..running the newest update on OSX...and none of the words are comiing up..I can still pull up the sounds..I just can see what im working on when they are there..I hope I was clear enough!!
help!!!
thanks
C
help!!!
thanks
C
- qo
Re: help!!!!
When you say "newest update on OSX" do you mean latest OSX, or latest MachFive? This (lack of preset names showing up) was a known issue with beta versions of MachFive which was fixed a while back. Unless you're talking about something else?singtou wrote:i dont know what happend but im pulling up mach 5 in DP now..running the newest update on OSX...and none of the words are comiing up..I can still pull up the sounds..I just can see what im working on when they are there..I hope I was clear enough!!
help!!!
thanks
C
I dont think im running a beta...
I just got the latest update from the website..and man I still get no menu showing up...I can pick the sounds...they just dont show up on the mach five when I pick them..and yes..I have the newest update on OSX as well...
please help!!!!
thanks
C
please help!!!!
thanks
C
Mach Five Graphics
I have also had this issue with Mach 5 after upgrading to Tiger 10.4.3 and
Mach 5 v1.2.3 with DP 4.61; no names in the preset window or anywhere in M5.
- doodles
it's a known issue - i had the same problem when upgrading to tiger a few weeks back.
contacted distributor. they told me to download an earlier version of mach5 - install that, then install the updates. somewhere along the line there is the font in one of the install packages.
i did it, it works fine now...
Do you know what font and where it should reside? I don't have the problem but would love to be prepared.... TIA.doodles wrote:it's a known issue - i had the same problem when upgrading to tiger a few weeks back.
Apparently this was (is?) a common issue. This is from Josh Hetrick at motu tech support:
-Quit all applications.
-Go to /Library/Audio/Plug-ins/Components, and trash "MachFive AU.component.
-Go to /Library/Audio/Plug-ins/MAS, and trash "MachFive MAS.bundle.
-Now run the latest MachFive 1.2.3 installer from our website.
Fixed the problem.
In the process of backing up my system to prepare for an cpu upgrade, and later, Tiger, I skipped installing M5 from my disk and just used the installer (1.2.3) from the web. The only reason to use the M5 disk was to install the demo tune. No problems!!!
Hope this helps.
Fixed the problem.
Hope this helps.
Holy Crap! You guys rock and you ROCK HARD! I was freaking out since I (stupidly) decided to upgrade (another post got me wondering why my streaming wasn't working in MAS) during production on a project. Imagine my surprise when I open up MachFive and I can't see the names of any of my sounds!!!
Anyway, the above solution works. Geez, you'd think this would be in the MachFive Tech Notes on MOTU's site!
THANK YOU EVERYBODY!!!
Quad G5 - 4GB RAM; PB 17" 1.5 GHz - 1GB RAM; OS 10.4.8, DP 5.11, Digi 002R, Mbox, Pro Tools LE 7.1, DV Toolkit 2, Music Production Toolkit, MachFive, NI Komplete2, EWQLSO GOLD, MemoryMoog Plus
