hello everybody,
first of all, i think that MX4 is an AMAZING synth!! now my problem:
i've installed the mx4 2.0 demo on my desktop g5, and i was so pleased with it, that i also installed it onto my laptop. so far so good...but then i decided to reformat my laptop, and re-installed the system from scratch, not using the migration assistant, but re-install everything again by hand...
so after installing and updating the system up to the most recent tiger version 10.4.6, i installed logic pro 7.2, and first thing i reinstalled MX4, but now i'm getting this error message in the AUvalidation in logic:
the pop-up message says:
Required software extension are missing.
The shared library named "<ILUIEngineLib
Carbon><ILUIEngineLib Carbon><URLAccessLib><" could not be found. Please install this library or contact customer support for this product.
and the auval log says:
AU Validation Tool
Version: 1.1.2c11
Copyright 2003-4, Apple Computer, Inc.
Specify -h (-help) for command options
VALIDATING AUDIO UNIT: 'aumu' - 'MX4!' - 'Motu'
Manufacturer String: MOTU
AudioUnit name: MX4
Component Info: Modular Synthesizer
Component Version: 2.0.0 (0x20000)
Component's Bundle Version: 2.0.0
* * PASS
TESTING OPEN TIMES:
COLD:
FATAL ERROR: OpenAComponent:result= 1,0x1
could somebody help me out with this?
specs:
- dual 2.0 g5, os 10.4.6, logic pro 7.2, motu 828mkII
- 12" powerbook 1.5 Ghz, os 10.4.6, logic pro 7.2
tell me if i should give more details...
thx in advance
PS: i don't seem to be the only one:
http://www.motunation.com/forum/viewtopic.php?t=7277
"Libraries missing"-error in Logic Pro 7.2 (drivin
- taiski
hello hugy,hugy wrote:Hi,
You can try to validate the plugin manually. (click the check box)
With some luck, it will open in logic as it do in DSP-Quattro.
Good Luck
Regards,
yes, obviously that's a workaround (which works fine) but it's very annoying, since you get a pop-up message warning you each time you start up logic... also looks quite ugly if a client sees that, no?
