Traveller and QT 7
ritzybiz
Traveller and QT 7
Post by ritzybiz »
My traveller has stopped playing back Quicktime files - I just get strange high intermittent digital noise. If I switch to internal audio, I have no problems. Any help would be great.
G4 Dual 1.8 Traveller 1.05 firmware, latest MOTU drivers
DP4.61 (works fine), Soundtrack Pro (which won't play thru Traveller),
Quicktime 7.0.4, OSX 10.4.5
Cheers,
Charlie
lunaticDP
Traveller and Quicktime does not work: The same here!
Post by lunaticDP »
Wanted to compose the soundtrack to a promotion DVD, but when I log to the referenz-video (QT DV-mov) all my audiotracks are not heard anymore, although I can see that they play. If I split the audio from the video and close the movie all the files are heard includuing the sound from the video. very strange; If I switch to build-in audio everything works fine also with the video.
anybody got an idea?
lu
Forgot to mention: this is not on my G5 but on my G4 DP1,25 and on the PB17" with the Traveler connected.
MacPro 3,3GHz 6-core, 16GB, OSX 10.7.5, dp8, mach five 3, msi, motu 2408mk3, 2x 1224, 308, melodyne editor, stylus rmx, omnisphere, trilian etc.
Resonant Alien
Post by Resonant Alien »
Make sure your Default digital input is set to ADAT - even if you're not using ADAT - this should "fix" the problem - had the same thing with my 828mkII
lunaticDP
Traveller and Quicktime fix
Post by lunaticDP »
Resonant Alien wrote:Make sure your Default digital input is set to ADAT - even if you're not using ADAT - this should "fix" the problem - had the same thing with my 828mkII
thanx a lot I‘m going to test that this evening!
lu
