doe anyone sell sound enclosures for computers. the fan on my g4 is very loud. i'm looking for an option other than having the power supply replaced.
maybe i could build one?
thanks
sound enclosure
Do you have a Dual MDD G4? I have a Dual MDD 867 G4, and when I got it, it was almost unusable due to fan noise.
I followed recommendations of G4noise.com (now defunct) and bought the Verax fan kit and their modified processore cooling fans.
Plus, I installed some sound absorption and some cardboard 'airflow modifications' inside the case.
You should be able to find out more by searching the Web...G4 noise solutions, G4 silencing, etc......check out 'Xcelerateyourmac.com' as well.
Find the Verax USA website....somewhere in Iowa.
Now, I can record with my Mac anywhere, anytime in relative peace and quiet! Get the Verax kits...they work...and add the cardboard airflow modifications.....check it out.
Cam Millar
Cam Millar
- emulatorloo
Re: sound enclosure
See this thread here -- link to DYI enclosure project:guitarsark wrote:doe anyone sell sound enclosures for computers. the fan on my g4 is very loud. i'm looking for an option other than having the power supply replaced.
thanks
http://www.motunation.com/forum/viewtop ... =enclosure
I haven't done it but it looks fun!
ON edit; original link gone, here is new one:
http://www.billshafer.com/isobox.htm
Here also another one, based on a bush furniture office cabinet -- this is a linked word document, but his box looks mighty good:
http://homepage.mac.com/osxlover/ParisFAQs/isobox.doc
Another one here:
http://efod.se/writings/quietbox
Some general ideas from an electronic musician article:
http://psbg.emusician.com/ar/emusic_sound_silence
<snip>
If you decide to take the DIY route and build your own custom isolation box, be sure to keep ventilation in mind. A simple plywood box with some acoustic foam on the inside can provide significant noise reduction if you're careful to make tight-fitting seams and caulk them to prevent any leakage. Use weather stripping to ensure a tight fit on the doors, and put intake and exhaust fans on the back of the unit. You can even make your computer's case into an isolation box by lining the inside with absorptive foam and sealing any gaps. Remember, you'll need to leave at least one hole for air intake and another for exhaust.
<snip>
