Expert Mode
riproryn
Expert Mode
Post by riproryn »
Part Select sounds like a groovy function. Does it work? I've been trying for days now to no avail. I suspected corruption and re-installed, repaired permissions, threw away prefs, stood on my head and chanted my mantra backward...etc. It ain't workin'.
Any suggestions?
Many thanx,
rn
DP 4.12
Mach 5 v1
Oxygen 8 controller
dogman67
Expert Mode
Post by dogman67 »
After all this time you've probably figured this out but here goes:
Enable Expert Mode. Load a couple of parts, say, a given instrument with two different articulations like violins legato and violins pizzicato. Click on the E, choose Part Select, turn the part select ON for both parts and set them to the same MIDI channel. Double click the note name and assign a a seperate note for each part outside the instrument's range on your kbd. Now you will be able to toggle between the 2 parts on the fly by pressing the select notes.
