anyone use dp and tascam dm-3200 console ?
ZENZOMIX
Post by ZENZOMIX »
please share your impressionjavascript:emoticon(':P')
runde1
Post by runde1 »
hey!
i use dp on my mac and the dm3200 w/ optional firewire card. i have serious problems with sending mtc from dp to dm 3200. another problem is that i get pops and clicks while recording. tried to change buffer settings, sample rate and stuff, but nothing helped.
Macinbowl
Post by Macinbowl »
runde1 wrote:i have serious problems with sending mtc from dp to dm 3200. another problem is that i get pops and clicks while recording. tried to change buffer settings, sample rate and stuff, but nothing helped.
Your pops and click pobably comes from the problem you have syncing DP with the DM3200. These are common with clocking problem. My guess is that you need an external clocking device set as a master clock like the Motu MTP AV or the Apogee Big Ben. You can probably fing one a little bit less expensive.
Mat
Imac Intel core 2 duo 2.33Ghz-2G ram / Macbook Pro 17" core 2 duo 2.33Ghz-2G ram/DP5.12/Logic 8.0.1/M5/MSI/BFD/828/RME Fireface 800/EMU 0404/Dynaudio BM5A
mountain
Post by mountain »
I JUST Bought One Tascam Dm3200
and in the setup stage
still cannot yet setup the adat, see my previous post
i cannot see DP output with adat channel
later tell u what am i think on this board
DP 5.1
Rosetta 800 X firewire
Big Ben
Tascam DM3200
