Frodo wrote:billf wrote:All this has made me wonder if MachFive is a dead end product. This is a case where MOTU marketing is dropping the ball.
When you consider the irony of how open-ended MachFive set out to be and how far ahead of the curve it was at the time, your question bears asking. It may not literally be a dead-end product, but for the way it's been kept so quiet over 2 NAMMs it may have a certain support shelf life.
That seems to sum up my concern so far as reflected in the comments of others in the way of technical support and third party support.
I'm still intrigued by stephentaylor's positive comment, but along with it I can't help but wonder in the midst of all else why we should get excited about all the new VIs shipping with DP5 when a major tool like M5 remains half cooked.
I like my steak medium rare, but my software has to be well done.
Frodo, you're such a supportive moderator of this interesting discussion that I thought I would at least make a comment of my own since I've been using M5 right from the week it was released.
I have both M5 and K2. There is no comparison between editing and mixing functions. K2 wins hands down. You can tweak everything with expandable, click-down windows and you can even do mixing, routing instruments to AUX channels with convolution reverb, etc., all with relatively little pull on the CPU. I'm a composer, not an audio engineer, and since I first came to audio via the manuscript paper route, I still sometimes tremble a bit inside the mixing windows of biggie sequencers (especially Logic!) but I find Kontakt to be one of the easiest interfaces for handling audio around, bar none. All the meters, knobs, buttons, and faders are beautifully designed, easy to see, and (almost) intuitive. And it's all laid out in a spiffy way. Now I only wish NI would come out with a sequencer.
As for conversion, I flawlessly converted the entire VSL Opus I and II libraries from EXS 24 to K2 format in just a few minutes. A piece of cake. Then I put them in the QuickLoad menu of K2 for easy access from a pop-up.
Also, the instruments themselves in Kontakt are vastly superior to M5, even including a basic set of Vienna SL orchestral insruments which you could orchestrate just about anything with in a pinch. No muted brass and other omissions, but hey, the basic instruments and articulations are there.
Another example. Recently, I needed an patch with a full church pipe organ sound, so I went to M5, and sure enough there was a great organ sound, even playing dim chords or major or minor chords. I used it in a short cue I was doing. Then I happened to be messing around with K2 and noticed the organ patches there. I played them and was zonked out by the superior quality. M5 sound felt like the local church. K2 sounded like Notre Dame or St. Peters in Rome (or even better, St. Mark's in Venice, which has two opposite choir lofts).
The best patches in M5 are the ones that SoundBank produced. Lots of variety and high quality.
One small source of irritation for me is that DP has dropped the ball for Logic users since the M5 AU plug-in doesn't validate in Logic 7.1. This has been a known issue at MOTU for months. They have mentioned it on their website and they even encourage you to check the AU for use anyway under the menu category "incompatible." I'm sure it is not that complicated to make the AU validate, but so far nothing from MOTU.
All in all, as others have said, M5 was an early effort and was quite novel when it appeared. I have used it in the past for conversion and samples. But now it is becoming the grey lady of samplers while glitzy stars like Kompakt 2 have taken center stage. It's kind of like Cher vs Jennifer Lopez. But Cher is famous for her comebacks, so let's hope an M5 comeback is on the horizon. I'll cough up for an upgrade if it is as good as MSI.
My 2-cents.
Bill
G5 Dual 2GHz 8 MB RAM, Edirol UA-25; WIN P4 2MB RAM, RME 96/8 PST Pro; Giga Orchestra, MachFive, Kompakt2; EWQLSO Platinum XP, Colossus, RA; VSL Opus I & II; Project SAM Brass, True Strike; Sonic Implants Symphonic Collection; 1st Call Horns
DP 4.6; Logic Pro 7.1; Cubase SX 3
