difference between OMF transfer and Digi Translator?
ryst
Post by ryst »
I am curious about this. Does anyone know the specific differences of what OMF files contain and do not contain when transferring the OMF project from DP to PT as opposed to Digi Translator? If someone has a list of differences that would be great. I can't find one yet. :oops:
Nathan-
Dual 2.5gig G5, 2.5gig ram, DP 4.6, Live 6, Battery, Kontakt, BFD, DFHS, EWQLSO Gold, Event ASP8's, Trigger Finger, M-Audio 1814, MOTU Fastlane USB, Ibanez MMM1, Schecter Stiletto Studio-5
ryst
Post by ryst »
Ok. I just found some info and now I am really confused. I don't use pro tools so bare with me here. If I save a DP project as an OMF file, can PT not open the OMF file without Digitranslator??? I thought DT was for more complicated file transfers. I thought it was possible to exchange OMF files between the two programs?
Nathan-
sevenone
Post by sevenone »
Nope, you need Digitranslator to open/save OMF files in PT. DP has the same thing built in as I understand it.
ryst
Post by ryst »
So basically DP can import and open OMF files but PT needs DigiTranslator to do it?
Nathan-
tommymandel
Post by tommymandel »
If you can still run OS 9, there's a tiny program called OMFTool, which will take the OMF you create in DP, and convert it to a Pro Tools v.4 session file, which any Pro Tools system can open (and then save as whatever version it wants it to be.) I haven't heard of an OSX version of OMF Tool, Maybe there is one, out there, guys?
dweiss
Post by dweiss »
Wasn't that only for 16 bit projects?
martian
Post by martian »
think it runs in classic... maybe I will try installing it on my laptop - must be worth a try cos -
Digitranslator2 is hilariously overpriced.... only it's not funny if you need it...
Not sure if does do 24 bit - assuming not ... could you not fool protools by making it 16 bit OMF first then force it to relink to the 24 bit media?
bralston
Post by bralston »
ryst wrote:So basically DP can import and open OMF files but PT needs DigiTranslator to do it?
That is correct and falls right in line with the Digidesign / Avid moto of "make them pay up the wazzu for absolutely every little feature."
:roll: :)
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
hearttimes
Post by hearttimes »
don't forget to toss in the extra 100 if you want to bounce to mp3 in PT
