24 i/o isn't seen by audio MIDI...help!
SamGlaser
Post by SamGlaser »
Hi. From one day to the next everything changed. I run a 2408 mk 3 and 24 i/o via a 424 card on a mac g5/2.7 running dp 4.61. For an unknown reason, my 24i/o isn't being seen by audiomidi. the 44.1 light just blinks. 2408 is working fine. Tried swapping out fire wire cords, diff. holes of the 424 card, etc. Thanks for any suggestions.
SG
sam glaser/www.samglaser.com
MacPro 2008, Sierra, 28GB Ram, DP9.5, Ethno, 24 i/0, 2408 mk iii
SamGlaser
24 i/o problems....
Post by SamGlaser »
Is there any "reset" function for this unit? I see that 13 ppl saw my post but none responded. Doesn't look like a good sign. Any advice?
Jidis
Post by Jidis »
Sam,
Sorry about that. If you didn't change anything, then it doesn't look too good for it. Beyond the cables and the different 424 jacks, all you've really got left are the PCI slots, but again, if it used to work... :cry:
Did you try running with only the 24 i/o (maybe on the same cable and port that the 2408 was on)?
Good Luck,
George
