Patchlist Question
mikecee
Patchlist Question
Post by mikecee »
How do I get my expansion card to show up in my patchlist in DP? And also is there a way to catagorize the patches for my Triton Rack by instrument.
mikecee
dp4.52 / G4 DUAL 1.6 /UAD/2408 MKIII/LOTS OF OTHER STUFF
semi pro sideman
Patchlist Question / i 2nd the motion
Post by semi pro sideman »
very timely 'q'!!!
:D
i also need to know the answer as a friend needs my tech support. he's got a triton pro. only the a bank can be selected.
...the only good is knowledge, the only evil is ignorance...
remmurd
Post by remmurd »
do a search for "Cherry Picker" for OS X.
Do what you love, love what you do.
toofar
Post by toofar »
In your MOTU folder you'll find an 'extras' folder that holds an expansion board setup utility. (I forget what it's called off hand.)
Bill
DP 11.32 | iMac 3.2GHz 6-core i7 & Monterey | Audient iD44 | FaderPort2 | MIDI Express XT | G4 dual 1 ghz MDD & Tiger | 2408 mk3 (x2) | A-500 PRO | Rosetta 200 | Toft ATC-2 | Mackie VLZ3 | JBLs | DP 4.6 | Live | 'n stuff
semi pro sideman
toofar wrote:In your MOTU folder you'll find an 'extras' folder that holds an expansion board setup utility. (I forget what it's called off hand.)
Bill
yep....that's the name and yep...tried it.
it was setup properly when we accessed it. should we be talking unisyn? if so, this seems an expensive solution to something that seems so simple. :?
i hope someone posts the fix :!: :!:
toofar
Post by toofar »
semi pro sideman wrote:yep....that's the name and yep...tried it.
Make sure in the ExpBd setup to select the board in the right column to match that of the left (or the other way round, i forget). It's counter-intuitive but you have to actually select them to enable them, even though they show in the one column. That's of course assuming that your Exp boards show up in the column. If not, then it's time for Cherry Picker, which works very well. Good luck.
Bill
