Hi Art,art bain wrote:Just a thought, but do you have "Edge Edit Copy" checked in the Sequence Editor mini-menu. If you do, then every edit you do creates a new soundbite with a new name in your soundbites window. You can wind up with lots 'n lots of bites!
You're right when you mention that you end up with lots of soundbites with "edge edit copy" enabled. However, when things are working correctly each new soundbite has a unique name. In my case (and apparently Zed's) the soundbites multiplied but each one had exactly the same name and durations as it's siblings. Definitely not working the way things are supposed to.
