convert mono to stereo
digsy
Post by digsy »
i know this is a stupid question but oh well.
i dont think i ever learned the proper way of converting a mono file to stereo in dp during the mixing process.....how does everybody do this?
the way ive been rigging it was by adding a stereo plugin to a track and bypassing the plugin. but i realized this is eating up lots of processor power. yes i have the manual but its not telling me what i want to hear.
thanks.
Spikey Horse
Post by Spikey Horse »
Not sure quite what you mean....if you are mixing to a stereo file then it will automatically become 'stereo' in a sense. A mono track can be panned to a postion in the stereo field of the final mix, or left central.
It just depends what outputs you have selected for the track's output - eg a mono track can be outputted to 'analog 1' or 'analog 1,2' - you don't have to make any other changes in the track itself.
Is that what you meant?
gearboy
Post by gearboy »
Copy the track to a second track and pan each hard opposite L/R. Make sure that the faders for each track are exactly the same. If you choose you can work like this or bounce them to a stereo track so that they are both on one fader.
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
digsy
Post by digsy »
i c but i noticed a long time ago that when i add a stereo plug in to a mono track, and switch to the mixer, it appears to have changed the track to stereo but when i switch to the edit window, the waveform is still mono.
so with all this said, is this track now stereo or is it still considered mono?
thanks
chrispick
Post by chrispick »
digsy wrote:i c but i noticed a long time ago that when i add a stereo plug in to a mono track, and switch to the mixer, it appears to have changed the track to stereo but when i switch to the edit window, the waveform is still mono.
thanks
In the above case, the source audio is mono. You haven't changed the waveform, only the conduit through which it's processed. If you bounce it to a stereo track, that newly-created audio file will be stereo.
Tim
Post by Tim »
Of course, it will still be a monophonic sound, only now it takes up twice the drive space.
A mono source will always be mono (sounding) unless a sterero (time based) effect is added to make it sound like it's in stereo.
What is it your reason for wanting to make the mono file stereo?
chrispick
Post by chrispick »
Exactly, yeah. I should've made that clarification.
Well, come to think of it, nobody should have to.
