Kernal Panic,any suggestions?
hi ,i have been having a smooth ride on my new G5 the last few months until the last few days.3 days ago i had my 1st Kernal panic rebooted computer ,repaired permissions and everything seemed fine the last few days,then this morning after i closed DP i had another kernal panic,and could not get system to reboot,so i shut down.(i guess it's time for Diskwarior tonight)last week i added a M audio 88 key controller to the system,it is running off of a powered USB hub, can having the keyboard not powered directly off of mac USB cause a kernal panic?would keyboard usb coming off monitor's USB be better or should i have his directly off mac... thanks KG
Just a thought here:
I don't have an M audio 88 key controller however I have learned that some M-Audio USB gear I have is very fussy and do not like to be plugged into a USB hub.
For example my M-Audio midiSport 8x8 can't handle the flow of MIDI data unless I plug it directly into my Mac and if I don't it will get that black curtain of death.
Perhaps your manual does or does not warn you about where your M audio 88 key controller should be plugged in.
Mac OS: Mojave
thanks for the replies......i took m audiio off of hub,repaired permissions and ran diskwarrior,everything seems OK,the next 2 days i will give it a workout and verify if this was the problem ,thanks KG
That might be machine specific. I run a bunc hof M-Audio stuff off of hubs and have on a variety of Macs (G5 Dual 2.0;G4QSilver, PPC 9500, 7600, MiniMac, etc.) and they have never been a problem in terms of kernal panics. They used to disappear from time to time, but that has not happened since upgrading to a G5.midiw wrote:Just a thought here:
