MTP keeps rebooting computer
hubercraft
Post by hubercraft »
Im using DP 4.6 osx 10.39 when ever I turn off my computer keeps rebooting unless I unplug the usb cable from my MTV USB anybody esle having this problem? is there a FIX
stephentayler
Post by stephentayler »
Don't remember if there is a fix, but this always happened with my G4 as long ago as 4 years with OS9, and then with OSX.
Sorry I can't offer any help, but you are not alone!!
Stephen
Alan Lindgren
Post by Alan Lindgren »
It happens to me as well. Does anybody here know why?
Post by Shooshie »
Glad I'm not the only one. My computer is almost always on, though, just sleeping when I'm not around, so it doesn't matter a great deal to me, but it's always been annoying when I try to shut down for a storm or something. Thank goodness it's OS X, and not OS9. That caused real trouble in the old days.
thracks
Post by thracks »
I remember this one. It's been a while, but I think the only fix I came up with at the time was to hook my MIDI interface up to a powered USB hub.
Steve
2020 Mac Mini | Sonoma | 828x |
Audy O
Computer Restarts Endlessly / MTP AV
Post by Audy O »
My Dual 800 G4 with OSX 10.4.8 restarts endlessly when powering down when the MTP AV is plugged directly into the USB port of the computer.
Even when you pull the power plug and leave it out for an hour, it restarts when you put the power plug back in.
Here's a partial fix: Leave the MTP AV power "On" when shutting down the computer. It seems to happen only when the MTP power is "Off".
Only other solution is to plug the MTP AV into a powered hub but MOTU does not recommend it as they say they've had some timing and synch problems in some cases.
Any other solutions?
Best,
Audy O
Frodo
Post by Frodo »
I remember this problem as well. Power cycling did indeed (and still does ) involve leaving all peripheals on-- shutting down the computer first.
When booting, I still turn on all peripherals first and boot the computer last.
