First the equipment,
G5 dual 1.8 GHz w/ 1.5 GB RAM (10.3.9 OS X)
Quantegy branded Firewire 400 hard drive (works fine with Pro Tools HD systems)
two 2408 Mk II interfaces with a PCI-424 (G5 compatible) card
DP 4.61 software
two Otari RADAR II recorders (used as converters for the DP rig and as a redundant backup)
The RADARs and the 2408 Mk II interfaces were connected via TDIF
The sample/bit rates were 24bit 48KHz
We were recording 48 mono tracks. I had the consoldated window showing Audio Monitor (i.e. input levels) and the Tracks window.
I set the system parameters to 48 tracks/no busses (custom - not Mocha or others) and turned off delay compensation (even though no plug-ins were being used).
Power was monitored throughout the recording - no problems occurred.
After approximately 20 minutes, the system crashed. I didn't write down the exact info because I was trying desperately to bring the system back up again without losing too much of the performance. If I can repeat the crash I will let you know precisely what the messages were. What I remember from the first line was something about uneven or unbalanced stacks.
Upon crashing - the system displayed 10-15 lines of error messages - looked like command line style text and was superimposed over the GUI interface.
Also - upon restart the system reset the clock to 12/31/1969 ?!?
I am just trying to determine where the problem lies. Is this a DP or MOTU issue or do I have issues with my Apple G5 itself?
I have been using this rig extensively in my own studio - but never more than 24-32 tracks. Also, I generally don't track more than 4-6 tracks at a time.
Help!!!
Ken Landers
kenland@bellsouth.net
