I cannot seem to get my 828MKII to respond to a Mackie Control Universal via the 828 MIDI I/O using DP 4.61 The MCU responds to commands coming from but I don't seem to be having any luck sending to. I see the MIDI LED in and out flash on the 828 and test setup in audio MIDI setup does not show activity from MCU. It will run flawlessly with one of my MTP/AV's so I know cabling and the MCU are working but why not thru 828••™s MIDI?
Has anyone else gotten this to work, am I retarded (don't answer that)???
I had originally asked this in the DP forum and only got one response from the Resonant Alien (Props to the alien)
Please respond, a yes or no will work••¦..
Mackie Control Universal w/ 828MkII
If you like us tell a friend, if you don't, tell an enemy. www.fingered.net
First Thank you for the responce shanabit.shanabit wrote: Next, I set the VS/HUI to go directly into the 828 MIDI I/O and connectec their cables in AMS
= No Problems
Your response tells me that there is hope and I seem to have a hang up with my 828 MIDI input being recognized in AMS. When I run the test setup in AMS using any of my other MIDI interfaces I get conformation in both directions (arrow for in and out blink and I get the dinging sound) but not with the 828 only the outs seem to work. I really don't need it as the only time I use the MCU is at work. I only use the 828 for recording in the woods and the like running an oxygen8 for MIDI input. I was fiddling around at work with the 828 and my Curious George nature got the best of me and I have gone a little crazy trying to get it to work.
