solution to noise problems with G5 powermac/motu828mk2
Stop the clips, pops, beeping, whirring and mouse movement sounds coming from your computer by fitting a 'ground loop suppressor' (£8.00 from Maplin/RadioShack) I bought a car audio one made by Shark from Maplin (product code VW43W) and fitted it inbetween the output from my 828mk2 and my mixing desk (to see the product use this link http://www.maplin.co.uk/Module.aspx?Mod ... 2&doy=18m9 ) It has totally stopped the problem even when the levels are near maximum.
Solution to noise problems
I'm having the same issue....Did anyone else try this?
Damien
Damien
Damien Masterson http://www.damienmasterson.com
or enter my name in any search engine
http://www.myspace.com/damienmastersonmusic
http://cdbaby.com/all/damienzm
415 305 7138 dzm@damienmasterson.com
Damien Endorses Hohner Harmonicas and Audix Microphones
Download the CHUD development tools from the apple site. Install. There will be a new system preference called "processor" and uncheck "allow nap"
Problem solved
http://developer.apple.com/tools/download/
Thank me later
Problem solved
Thank me later
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
