Hi,
Im going to get a Powerbook to duplicate some work...
Can I successfully use an external firewire drive for both audio and my Mach 5 samples?
Do I need two external drives?
Just keep my DP and Mach 5 applications on internal drive?
Any suggestions most helpful! Thanks all.
Powerbook - use external hard drive for audio and samples?
dunno bout mac drive speeds, but ideally you should use 7200 speed drives for audio and samples (unless you have massive ram memory so can load it all in ram).
I ended up opting for a spare battery in my HP Centrino's spare slot rather than a 2nd drive soley because the drives they had for that slot were only 5400. Course I get 6 hours continual music usage now, so am quite happy.
If you need to continually load from disk, then separating your samples from your app by using separate drives is probably a good idea, tho am sure another can confirm that.
- RJ Wade Music
I agree. I use a Powerbook with MachFive & DP 4.61. I use an external Glyph Firewire drive. I've placed my MachFive Sounds Folder on the external drive. I've had sesssions of about 16 tracks 44.1/24 bit and used 6 live MachFive Instruments and things where just fine. A second drive is definately the way to go.
RJ Wade Music, Inc.
Songwriting/Programming/Engineering
MacBook 2 GHz Intel Core 2 Duo 2, 4GB Ram, 80GB Internal Drive, Mac OS 10.7.5
MOTU 828mkII Audio / MIDI Interface
Glyph GT050 120GB FW
Glyph GT050Q 250GB, FW 400/800, eSATA, USB2
MOTU Digital Performer 7.24
Machfive 3.0
Melodyne Editor 1.1.5
Waves GOLD V8
BIAS Peak 6.2
Mackie HR 824 mk2
M-Audio Keystation 61es
Machfive 3.0
Waves GOLD V8
BIAS Peak 6.2
Mackie HR 824 mk2
