Suggestions for PC Card with FW 400 or 800???
gearboy
Post by gearboy »
Well, I finally took the plunge and bought a Powerbook for an upcoming recording project. I will need to pick up a PC card to run a second FW bus.
I'm wondering if anyone has had success running an 828mkii off of the PC card slot in this manner and can recommend makes and models. I am planning on running a FW800 drive in the future, and since the PB has FW800 built in, I figure the 828mkii can take the card slot position.
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
Steven Bell
Post by Steven Bell »
These guys seem to be really good at firewire products.
I got a two port PCMIA card from them.
http://www.unibrain.com/
Steven
5inusoid
Post by 5inusoid »
Can't you just run the FW drive out of the 828mk2?
gearboy
Post by gearboy »
I know that folks have had better luck running both the drive and the 828mkii off of separate FW ports. This allows for quicker drive write times and better throughput, if I am correct. I believe that some folks have experienced artifacts in the audio etc when daisy-chaining, and that MOTU doesn't recommend chaining a drive that's running off of AC into the 828mkii. I know that I read that here on Unicornation at some point.
Since I'll be working remote with clients on two full length records and two EPs between Philly and NYC in the coming months, I want the best system that I can put together.
Jeff
kelldammit
Post by kelldammit »
can a cardbus firewire/usb card even supply power (without an external a/c adapter)? i thought that on my friend's pc, it would not. if it can though, that's the route i want to go as well...
in the meantime, i got a targus chillhub. so i have my traveler running on the firewire400 slot (bus powered), and my mouse, MIDI controller, and flashdrive on the chillhub (apparently bus power from the usb port is enough! i don't have to use the wallwart!), leaving my second usb2 port open for a bus-powered hd.
i'd really prefer to use a fw drive though...
kell
gearboy
Post by gearboy »
Well, I hit CompUSA for a laptop sleeve today and checked out some PCMIA FW cards. All of their stock is (surprise :roll:) PC only. So I'm back to square one.
It is suggested that you run two separate FW busses, one for the 828, one for the drive. Each of them can run off of their own power supply this way.
My drive is also USB2.0, so I am going to experiment with that side of the fence this evening. I still want to run everything FW, so a card is in my future.
Any more suggestions will be appreciated.
Jeff
kelldammit
do a google search for lacie firewire 800 pcmcia card. i think b&h has them for $80 or so. it's pc or mac. however, i think my suspicion is correct, as an a/c adapter is included with the card.
so pcmcia cards cannot bus-power without an a/c adapter of their own...i want to say it had something to do with the pcmcia bus itself not drawing enough power from the machine to do so.
this being the case (i want to minimize the wallwarts necessary for my mobile setup), i'll be going with a bus-powered usb2 drive...
if you plan on using the a/c adapters for the interface and drive, then you're all set anyway...you shouldn't have to use the adapter for the firewire card.
kell
rockitcity
Post by rockitcity »
I have a G4 Powerbook (see below) to which I have recently added an Adaptec firewire PCMCIA card ($.99 on e-bay!). It has 3 FW 400 ports and an external power input. I purchased a 12 volt power adapter to supply power to the firewire card for the drives (2 60 GByte Hitachi 7200 rpm Travelstar notebook drives in external cases). My Traveler interface runs from the Powerbook's built-in FW 400 port, but I use an external power supply with it as well.
I mainly purchased this card because I was getting drive-access noise from the Travelstar drives in my monitors from the Traveler. Splitting the drives to the firewire card completely solved the problem. I believe that PCMCIA cards are cross-platform compatible, so one for a PC will probably work in your Powerbook.
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
gearboy
Post by gearboy »
Can you let me know which model you have? Does this have the Texas Instruments chip in it?
Also, I kind of figured that a PCMCIA would most likely work for Mac as well. I just want to do the research before jumping in, which is what this thread is all about.
Thanks for the information!
Jeff
gearboy
Post by gearboy »
Rockitcity, is this the PCMCIA card that you have?
http://cgi.ebay.com/ADAPTEC-AFW-1430-Fi ... dZViewItem
$.99 is a steal. I'll see how I do.
Jeff
kelldammit
rockitcity wrote: I believe that PCMCIA cards are cross-platform compatible, so one for a PC will probably work in your Powerbook.
a lot of wifi cards are not :) so, be careful.
.99 is a sweeeet deal!!!
rockitcity
That's the one. I purchased it from another seller who had plenty up for auction starting at $.99. Of course, shipping was $12, but it was still a deal. It came with a couple of cables, but did not include the external power supply, which I bought locally for about $18.
I called Adaptec about the chip, and they claimed it had a TI controller. However, I hooked it up to a PC, and it said it had an NEC chip. Doesn't seem to matter, as it is performing perfectly in my G4 Powerbook. I have not hooked up my Traveler interface to it, only the drives. There is a note on MOTU's tech support section warning about potential problems with NEC chips. Dunno. Works for me, but I am not recording a lot of tracks at a time (2 or 3 usually). Playback does not seem to be a problem with multiple tracks.
Here's Adaptec's info:http://www.adaptec.com/worldwide/produc ... 4+Adaptors
gearboy
Post by gearboy »
Hey rockitcity, I just bought the same Adaptec PCMCIA card that you use off of eBay for $10.50. With shipping it came to $21. Comp USA wanted $60 for it, so I'm happy, as long as it works.
Thanks again for the info!
Jeff
