Multiple track Color change shortcut
I think I've lost mind as I can't for the life of me remember the shortcut to change color in multiple tracks
I thought the routine was highlight the number of tracks you wanted to change color , hold the 'T' key and
click on the color icon and all tracks highlighted will change to whatever you point to in the color palette
once it opens. I've tried other keys , searched the manual, searched Shooshie's user tips database
and I'm drawing a blank.
Any clue ?
As Always Many TIA,
Schweats
Any clue ?
As Always Many TIA,
Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
- Shooshie
Re: Multiple track Color change shortcut
Setup / Colors / Assign Track Colors
This brings up a dialog with numerous options. The last option sets selected tracks to the same color. When you choose it, you will see a color swatch appear at the bottom of the dialog box. Click it, and you will get your color chart. Choose a color, and all selected tracks will go to that color.
- dave pine
thanx, i was on the phone with tech support last month for 20 minutes and they couldn't figure it out.
mac pro 2.26 octacore 24gigs of ram/ El Capitan10.11, dp 10, mackie dxb, 3-2408mk3, waves mercury 10, ozone 3&4&5678, sound toys, izotope rx, melodyne editor, uad 2, bluetubes, 22" polkadotted dildo, omnishpere 2, trigger 2 deluxe, addictive drums, komplete 9, e/w ql symphonic orq platinum, ql choirs, ql stormdrum 2, ql gypsy, ql ra, ql goliath, ql pianos, superior drummer 3, ez drummer 2, garritan bigband, amg kickass brass, ztar, wife, dogs, droped my protools rig at the city dump
- bralston
It is that procedure...but it is finicky. you have to do things in a specific, correct order. Highlight all the tracks you want to change color....then hold down T key....keep holding....then with mouse, click on color square....keep holding T key....navigate to color you want...are you still holding T key?...good.... select new color...on release of mouse button all will change. then of course release t key. It is the release of the mouse button on new color that makes the change...when the T key is continually pressed.Schweats wrote:I think I've lost mind as I can't for the life of me remember the shortcut to change color in multiple tracks
Any clue ?
As Always Many TIA,
Schweats
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
If you assign the tracks to a Group, you can set preference so all colors, and many other things, change together.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
- FMiguelez
You can double tap it and it will "stick", so you don't need to keep holding itbralston wrote:
Tap it again to go back to normal.
Same applies to w.
- Radiogal
Select the tracks and press & hold T and change the color on one of the selected tracks.
This "T" short cut can be used on about all track related stuff.
EDIT.. cool to know the "T" can be stuck double tapped..
- Dwetmaster
Use Shooshie's method and be done with it. Assign a key command to that for quick recall...
Well...it looks like you wrote this 12 years ago, but thanks again for this in 2025!Shooshie wrote: ↑Wed Jan 23, 2013 2:58 am Setup / Colors / Assign Track Colors
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
Unfortunately he hasn't been around here in quite a while.
IIRC he dialled the music-making thing right-back or to the off position several years ago in order to make time for "life".
I really miss Shoosh; there can only be one Shoosh!
Oh yeah, the double-tap-T thing was covered in a DP webinar IIRC, which would've obviously been more-recent than this 12-year-old thread.
Amen to that, brother.
