PinkLine wrote: ↑Sun Apr 13, 2025 5:01 am
My first question is whether the older MOTU AVB device chipsets support the AAF-PCM stream format, such that AAF-PCM or AMB-24 could be offered as a user selection via a firmware update.
Unfortunately No.
The older MOTU AVB devices can only support the "legacy" AM8-24 stream format, which is not compatible with MILAN.
My second question is whether the 2025 MOTU 16A (or some other device) could be used as a bridge between an AMB-24 network and an AAF-PCM network. I see the new 16A allows selection of AAF or AMB-24 per stream.
Fortunately Yes.
The (2025) 16A is designed to be that "bridge" between the old AM8-24 stream formats and the newer AAF-PCM stream formats.
As a result, the (2025) 16A can be integrated into a network that has MILAN certified devices.
does the MOTU AVB switch work with both AAF and AMB-24 streams
It should.
My understanding is,... AVB certified switches can accept and pass along any type of AVB stream format on the network.
Lastly, as of now (April 2025)
MOTU is not yet a member of the AVNU Alliance so its products cannot be MILAN certified, but that doesn't prevent them from implementing aspects of the MILAN spec, It's still all AVB.
PreSonus is a member of AVNU but none of its current AVB products are MILAN certified.
My guess is because those products all use the AM8-24 stream format.
RME currently has eight MILAN certified products.
AVID currently has one (for the VENUE console).
NETGEAR is working on MILAN certification for their M4250 Series Switches.
Hope this helps,
PhireAlly
